1999 Disco II 'The Rhino' 172,000 miles and going
The original owner has been using 5/10 Mobil Synthetic, the Disco II 1999 has 168K ?
What would be the best oil for such high milage?
The City is a Jungle. ![]() 1999 LR Disco II SD The Rhino ![]() 1991 RRC (Sold) We will miss the Turtle ![]() 1988 RRC (sold) |
got mud?
The best and most expensive is Royal Purple. You should be fine with Mobil high mileage oil (mobil makes Great oil!). What weight depends on the weather. Probably a 10w-40 for summer and 5w-30 or something for winter. It never gets cold here so I don't know.
Synthetic is always a good choice.
DII -- Pete 285/75 r16 Destination M/Ts |
Britabroad
Here we go again....
No Dis - Safari Dave - search a little there's tons on this. FWIW - My shop was using 10w50 (possibly Castrol) but I started doing my own changes and switched to MaxLife 10w40. It uses no oil at 100k (the 10w 50 seemed to need 1/8th every 3000 miles) I think most people will say use a good brand - rate as recommended by LR and use either the Mobil 1 or K and N oil filter. They have a valve that prevent oil drain back so you don't risk oil starvation on start up. Enjoy. |
Stay with the Mobil 1 but go to a heavier weight, what is being used ie way to light. Depending on your weather, I would suggest something between a 10W/30 or a 10W/40 and switch to Mobil 1's extended mileage oil for even better protection on the soon to be a high miler.
Mike |
Mike, the original owner used synthetic. Should I use Mobil Synthetic 10/30 for high miles?
When is a car considered high mileage?
#9 (permalink) | |
Ditto on the Rotella T - I have used 15/40 since I have owned mine.
"Peter, can you hold my ears?" I think Cvc's goal is to make me vomit daily with his disgusting avatars. |
#10 (permalink) |
Rotella is a excellent choise for flat tappet engines like Rovers.
Search is TRULY your friend on this subject....Thats all I'll say on that. ![]()
When I was done with her, her bed needed Shamwow sheets! |
#14 (permalink) |
By using Rotella T my oil stays cleaner longer (due to lack of crud in the engine) and it makes oil changes a hell of a lot cheaper.
Reportedly Rotella T is high in detergent properties that clean. And my dipstick is proof! Scott |
| Thread Tools | |
| Display Modes | |
| Disco I Safety Devices Roof rack - high version | greekdisco | Land Rover Parts and Accessories | 1 | 12-20-2008 04:59 PM |
| obd two codes | Rovin4life | Discovery Series I | 4 | 12-25-2006 10:16 AM |
| Pre-95 Disco Newbie needs more advice | pfkb72 | Discovery Series I | 18 | 09-12-2005 10:49 AM |
| High and Low shifter on 98 Disco | JerryStlouis | Discovery Series I | 16 | 05-04-2005 07:06 PM |
