Old 08-12-2008, 12:16 PM   #1 (permalink)
Default Wheel Stud Replacement
Hi everyone...I bought my 99 DII from a Ford Dealership and apparently they used a lug not from the spare tire and stripped the wheel nut...I can't get a proper lug nut on it...can the wheel nut be replaced? or do I need to buy a new hub assembly?
IsoDisco
IsoDisco is offline   Reply With Quote
Old 08-12-2008, 12:17 PM   #2 (permalink)
Sorry...I mean the wheel stud has been stripped.
Old 08-12-2008, 01:55 PM   #3 (permalink)
jmrivera's Avatar
By the looks of the hub, the entire hub assembly must be replaced...
A couple of online sites have them and they are priced around the $350 to $450 range... Another site has used for about $200...
Land Rover - Parts, Accessories and Information
Wheels & Hubs - Hubs
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline   Reply With Quote
Old 08-13-2008, 06:21 AM   #4 (permalink)
Thanks for the links.
Old 08-13-2008, 07:47 AM   #5 (permalink)
If 5this is something the dealer did, you need to make them pay for the total repair cost.
Just so you know, the lug nut for the spare carrier have a dimple on them that the regular wheel lug nuts don't have.
Old 08-13-2008, 03:05 PM   #6 (permalink)
Dealer said no warranty sold "as is"...I won't be doing business with them anymore.
Does anyone know if this hub will replace the hub on my 99 DII? There are studs listed on this site as well...maybe I could replace the stud?
Rovers North.com - Land Rover Series, Defender, Discovery and Range Rover Parts - HUB ASSY w/WHEEL STUDS SERIES III
Old 08-13-2008, 03:21 PM   #7 (permalink)
jmrivera's Avatar
I'm not expert, but from examining the hub on my Disco. and looking at this one, I would have to say NO!...
I know it sucks, but I think you may have to go with either of the 2 I linked before... You many want to try to verify if you can get a new stud in yours, but since the hub appears to be comprised of 2 components (hub bearing and hub flange) that are pressed together, the clearance for mounting the stud looks to be too little...
But, like they say, start with the cheapest part first...
Old 08-13-2008, 03:58 PM   #8 (permalink)
Back in a Series LR after 25 years :-)
slouzon's Avatar
The link you have is for a Series III hub, a completely different animal.
Here is a link to the front hub on a DII.
Rovers North.com - Land Rover Series, Defender, Discovery and Range Rover Parts - HUB ASSM - FRONT w/SENSOR DISCOVERY II
It looks to me there is plenty of clearance to get the studs out.
Now finding replacements that maybe be another story.
Once you get one out a good auto parts maybe able to match it up for you?
Here's a better picture.
I bet you can get the stud out with only having to remove the wheel, caliper and rotor.
Than knock it out with a hammer.
Pull the new one in using a lug nut and some washers.
Steve
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
slouzon is offline   Reply With Quote
Old 08-13-2008, 04:06 PM   #9 (permalink)
jmrivera's Avatar
Steve
I pulled my hub this weekend and looking at it from top down, it's a hell of a lot closer than it appears... I'm not saying don't try, I'm saying it's not wide open like the hubs on my '72 Chevy pickup... You have to make sure you are on the little section that is notched out, and with it on the truck, it's not easy to see the notch...
Go for it!!!
Jonathan
Old 08-13-2008, 04:15 PM   #10 (permalink)
slouzon's Avatar
Well worst case the hub assembly may have to come off.
If you look at the picture there is even a notch in the base to clear the stud on the right side.
71 Series IIa 88
01 D2
Wheel seal replacement GentrysRover Discovery Series I 2 05-12-2008 10:34 AM
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 07:33 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Wheel stud pattern on 88 RR Chick Magnet Range Rover Classic 2 02-05-2005 05:04 AM
