Old 02-12-2006, 10:44 PM   #1 (permalink)
Nacho Libre
Hailsharky's Avatar
Default When you straighten out the steering wheel...
My mechanic explained this once to me.
He showed me under the front spoiler where there is a bar that has a 13mm and 17 mm bolt that you loosen and either wrench the bar towards you or away from you to turn the steering wheel.
Anyone remember which direction goes where ?
Hailsharky is offline   Reply With Quote
Old 02-12-2006, 10:57 PM   #2 (permalink)
I don't have a clue what you're talking about.
Is the problem that you're steering wheel isn't centered when you're wheels are straight?
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 02-13-2006, 06:27 AM   #3 (permalink)
4x4 Adventure Gear
John C's Avatar
That's your steering rod, one side is RH thread and the other is LH thread. It sets your alignment so I wouldn't touch it if I were you.
Bring it to a shop and have it aligned properly. If your steering wheel is off center then figure out why it's off center (panhard bushings might be bad, you recently installed a lift, etc).
The longer bar in the rear is your track rod.
Give us some more info and maybe we can help.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 02-13-2006, 10:03 AM   #4 (permalink)
Nacho Libre
Hailsharky's Avatar
Yes.
Old 02-13-2006, 10:05 AM   #5 (permalink)
Nacho Libre
Hailsharky's Avatar
It's probably the pan hard bushings then. In 3 years teh wheel was always straight.
Then this last year ive noticed twice that the steering wheel was off.
Looks easy enough to do, I just wanted to save time and know what direction went where.
Thanks.
