Note: The following is a list of service intervals that the dealership maintains, more frequent maintenance on any of the items is never a bad idea.
7500 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect trailer hitch attachment bolts for tightness Change front and rear axle oil Record performance of Service in Passport to Service 15000 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Inspect serpentine drive belt Check brake fluid level Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Record performance of Service in Passport to Service 22500 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Record performance of Service in Passport to Service 30000 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Replace Alarm handset batteries Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Inspect serpentine drive belt Change brake fluid *Replace air-cleaner element Change engine coolant Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect trailer hitch attachment bolts for tightness Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Change transfer gearbox oil Change transmission fluid Replace transmission fluid filter Check front and rear axle oil level Record performance of Service in Passport to Service 37500 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Record performance of Service in Passport to Service 45000 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Replace serpentine drive belt Check brake fluid level Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Inspect engine and transmission mounts Record performance of Service in Passport to Service 52500 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Under Vehicle *Change engine oil and replace filter Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Record performance of Service in Passport to Service 60000 Service Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010) Inspect wiper blades Lubricate door locks, check straps Lubricate hood latch and safety catch, fuel door hinges Replace Alarm handset batteries Interior Check parking brake (Adjust if necessary) Check seat belts Under Hood Inspect coolant hoses Inspect radiator and AC condenser Check power steering fluid level/ACE fluid level Clean battery and terminals Inspect serpentine drive belt Change brake fluid *Replace air-cleaner element Change engine coolant *Replace spark plugs Under Vehicle *Change engine oil and replace filter Perform body corrosion warranty inspection Inspect tire pressures, condition and tread depth Inspect brake pads, calipers and discs Inspect exhaust system and heat shields Inspect brake lines Lubricate drive shafts and U-joints Inspect steering rods, joints and dust covers Inspect shock absorbers Inspect suspension links and mountings Inspect trailer hitch attachment bolts for tightness Inspect wheel speed sensor and height sensor wiring Inspect fuel and hydraulic lines Change transfer gearbox oil Change transmission fluid Check front and rear axle oil level Service SLS filter (if equipped) Record performance of Service in Passport to Service
Oh wow... thank you so much! and what I mean by "on-road" is.. well, maybe I'm not giving the right information... whenever I activate the navigation system to take me to a specific location, the words "off-road" are to the right of the screen... so I guess I just assumed that it was giving me off-road directions... the navi CD was a copy made by the dealer who sold me the vehicle...
Thanks John-Robert |
| Thread Tools | |
| Display Modes | |
