Old 05-04-2008, 10:50 PM   #1 (permalink)
jmrivera's Avatar
Default Where to put Seafoam in '03 Discovery 4.6L???
Hi all,
I have read all about the magic of Seafoam and the Discovery, but I am not sure where exactly I would introduce this product into my engine... I have taken some pictures and placed a red circle around a hose the enters the valve cover on the passenger side of my 4.6L engine (see images below)... Is this the hose that I would use by removing it from the valve cover, rotating it 180 degrees, and slowly introducing the Seafoam into the intake manifold???
Thanks in advance!
Jonathan
jmrivera is offline   Reply With Quote
Old 05-04-2008, 10:58 PM   #2 (permalink)
got mud?
Jupiter Rover's Avatar
ok i may be wrong, but i am quit sure this is where..
in your First picture, Dead center on the intake there is a black hose with red ring around it. below that should be a little entry with either a cap or a rubber piece on it..
the little entry below the black hose with the red ring should be the spot.
DII
-- Pete
285/75 r16 Destination M/Ts
Old 05-04-2008, 10:59 PM   #3 (permalink)
got mud?
wait for a 2nd opinion to double check
DII
-- Pete
Old 05-04-2008, 11:10 PM   #4 (permalink)
2004 Discovery II driver
i'm interested too, i never get my vac line straight lol
stolenheron is offline   Reply With Quote
Old 05-05-2008, 05:56 AM   #5 (permalink)
Jonathon,
Buy 2 cans of Seafoam, one for the gas tank, one for the induction.
Also buy 2' of 3/16 tubing, attacah one eng to the lower fitting under where the v/c hooks to the manifold. Using a pair of pliare, while the engine is running squeeze the hose so there is no flow, but the other end of the hose into the can of Seafoam and allow the smallest amount to flow thru by slowly relaesin a small amount of pressure on the pliars. After you have sucked in the whole can, turn the engine off for at least 1/2 hour, might want to clean your t/body and idle control during that time with some carb spray.
Then go see how much smoke you can make.
Old 05-05-2008, 07:50 AM   #6 (permalink)
jmrivera's Avatar
Thanks for the clarification... I'll get the second can on my way home tonight and give it a go... Can't wait for the smoke screen.....
Jonathan
Old 05-05-2008, 05:53 PM   #7 (permalink)
if you put it thru there the pcv separator you may end up with problems.
if you have any leaks its a sure fire bet the separator is causing them cause its stuffed and causing excess pressure blowing out the intake gaskets and the valve covers.
The 03s and 04s are known for this issue. they like to suck up oil thru the intake.
Old 05-05-2008, 07:57 PM   #8 (permalink)
brooksa's Avatar
This is a pic from Disco Mike that he sent me,
2004 DII SE7
brooksa is offline   Reply With Quote
Old 05-05-2008, 08:07 PM   #9 (permalink)
jmrivera's Avatar
Lost and not sure if you're saying Disco Mike is saying the wrong place, or if I circled the wrong ares in my pictures.... Please clarify before O make a HUGE mistake!!!
Thanks,
Jonathan
Old 05-06-2008, 07:20 AM   #10 (permalink)
The nipple that you have circled is the best place to runn your Seafoam thru.
Old 05-06-2008, 07:32 PM   #11 (permalink)
got mud?
i like how your ignition wires dont touch your engine... all of my even number wires rub against the engine and get fried!
DII
-- Pete
Old 05-09-2008, 10:57 PM   #12 (permalink)
YellowFever's Avatar
Originally Posted by jmrivera View Post
Hi all,
Thanks in advance!
Jonathan
I was thinking about using this stuff so I read this post. I looked at the pics and went down and looked at my 00 Range 4.6. The motor looked the same except I don't have a hose attached to the red thing. (I circle mine it is black.) On my rover it has that red thing with nothing attached to it. Just curious why?
"Get busy living or get busy dying"
YellowFever is offline   Reply With Quote
1997 Discovery XD Serg Land Rover Vehicles 45 02-09-2007 08:47 AM
1995 Discovery 2.5 300 Tdi Offroader freelanderman Land Rover Vehicles 4 05-12-2006 09:44 AM
Land Rover Discovery 3 (LR3) Launched in Kenya Serg General Land Rover Discussion 1 11-20-2005 11:56 AM
RamAir Air Filter for Land Rover Discovery 1 95 Range Rover Classic $25.00 hamrendan Land Rover Parts and Accessories 0 01-24-2005 09:08 AM
Comparison between Discovery 2 and 3 Mark^^ Discovery 3 / LR3 1 12-28-2004 09:13 PM
