Whining whriling noise - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 13 (permalink) Old 07-14-2011, 04:18 PM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
Whining whriling noise during moring start up after it warms up it go's away.
The best way to explane the sound is a like a power steering noise when either low on fuild or under load.
I checked the PS fluid checks good the trans shifts fine but when driving sometime from a start I get the same noise.
I been wouldering if some how conected to the vibartion in the drivetrain 75 MPH and above New rebuilt Front driveshaft new rear full converted U-Joint rear drive shaft helped out but still 75 + these's still a vibration.
It has 104500 on the clock has not been off roaded it had a easy life 2003 Disco.
2003 Land rover Discovery, 2001 Dodge Ram 2500 with the V-10, 1986 Corvette money pit not stock.
marv02 is offline
post #2 of 13 (permalink) Old 07-14-2011, 05:31 PM
2003discoII's Avatar
Quoted: 1 Post(s)
sounds like the SAI vacuum,is it like a hair dryer sounds? if it is then it's normal
2003 disco. exhaust mod,265/65r18
2003discoII is offline
post #3 of 13 (permalink) Old 07-16-2011, 04:44 AM
Quoted: 0 Post(s)
Where did you get the shaft from? I replaced mine and it does the exact same thing
antelope44 is offline
post #4 of 13 (permalink) Old 07-16-2011, 05:35 AM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
Purchased my rear Shaft from Toodco Supensions Inc. the front shaft I rebuilt my self I had no noise after rebuilding the noise started after I installed the rear shaft.
The Stock rear shaft had some noisre but not like I starting to get now.
I think affter ai get my other car back on the road I take both shafts down and have them rebalenced.
marv02 is offline
post #5 of 13 (permalink) Old 07-16-2011, 06:35 AM
Administrator
Quoted: 5 Post(s)
Does the noise occur when driving or while stopped? Might want to remove the front shaft and rear shaft and have them inspected, neither shaft should make any noise. I would contact Toddco and make them aware of the issues before you do anything since they are under warranty.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #6 of 13 (permalink) Old 07-16-2011, 10:21 AM
prettynpink1029's Avatar
Quoted: 2 Post(s)
I had a similar noise right before my Oil pump went. I hear it's rare to hear a noise from it though. Changed my oil pump and noise was gone. Originally I thought it was power steering related. If you hear or feel a general change/roughness and clattering to the engine, shut it off asap (that's what happened when my oil pump went out).
-Heather
prettynpink1029 is offline
post #7 of 13 (permalink) Old 07-16-2011, 10:34 AM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
I got hold of them already due to they sent me the wrong Yoke conversion 1 week ago they have not gotten back to me I try to shoot then anouther E-Mail I just so busy need to find time.
At the same time trying to get my other car back on the road.
marv02 is offline
post #8 of 13 (permalink) Old 07-16-2011, 10:44 AM
Administrator
Quoted: 5 Post(s)
Call them, don't wait for their e-mail.
Need Parts?
Lucky8,
post #9 of 13 (permalink) Old 07-16-2011, 06:59 PM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
Like I said been very busy normaly I been working OT every weekend 12+ both days.
This weekend No Ot so I had time to put new trarnsmission in the Vett went and spent the rest of the day with the family.
Tomarrow the same work on the Vett and family I get up early so I have time to work on the Vett.
I will make time to call Toodco this comming week.
QUOTE=Disco Mike;395869]Call them, don't wait for their e-mail.[/QUOTE]
marv02 is offline
post #10 of 13 (permalink) Old 07-16-2011, 07:01 PM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
Oh ya after I get the Vett back on the road I planing to tear in to the Disco.
My only problem with this is me, once I start getting in to a project I go hog wild, All I need anouther money Pit LOL.
I just Might pull the motor to give a good once over check the Oil pump before it go's south drop a new set of bearing check the bore see if they are straight if so Quick hone and a new set of rings, run the valves and seats ect $700.00+ bucks for a quick look over.
At least I know it right.
Same for the trans take a quick look inside.
marv02 is offline
post #11 of 13 (permalink) Old 08-02-2011, 03:23 PM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
I had the driveshafts looked at I found out the rearend going out thats were my vibration comming from yep anouther Grand Oh great I didn't want to spend that money at this time so I work a weekend of OT to pay for this fix.
marv02 is offline
post #12 of 13 (permalink) Old 08-02-2011, 05:49 PM
Administrator
Quoted: 5 Post(s)
Just curious, when you rebuilt the front shaft, did you replace the centering ball also?
Need Parts?
Lucky8,
post #13 of 13 (permalink) Old 08-02-2011, 05:57 PM Thread Starter
marv02's Avatar
Quoted: 0 Post(s)
Yes I did replace the center bearning.
marv02 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
loud whining noise star05mpp General Land Rover Discussion 0 11-23-2010 01:48 PM
rear end yolk removal and replacement, now a whining noise? deadboy1977 Range Rover Classic 9 06-29-2009 11:02 AM
TC Light + Whining Noise zimwar109 Discovery Series II 4 04-09-2009 05:29 PM
squeaking/groaning noise and whining noise still D.C. Benny Range Rover Classic 3 03-03-2009 11:51 AM
Whining/Chirping Jack G Discovery Series I 6 05-10-2006 04:44 AM
You may post new threads
You may post replies
