Old 11-09-2007, 08:53 PM   #1 (permalink)
Default Why does my odometer blink?
The odometer flashes on my Discovery. Anybody else had this problem??
Wild Driver is offline   Reply With Quote
Old 11-10-2007, 01:58 AM   #2 (permalink)
It needs to have an odometer update performed on Testbook.
buick215 is offline   Reply With Quote
Old 11-10-2007, 06:33 AM   #3 (permalink)
How is that done?
Old 11-10-2007, 06:53 AM   #4 (permalink)
Need to go to your dealer and request they hook the Test Bok into your ECU.
Old 11-10-2007, 11:30 AM   #5 (permalink)
msggunny's Avatar
Gallery: 5
Its just the way your Disco tells you it loves you.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
When god gives you lemons, find a new god....
msggunny is offline   Reply With Quote
Old 11-10-2007, 12:52 PM   #6 (permalink)
D2D
original milage is kept at the ECU if there is a difference between ECu and the odometer it blinks... check the owners manual
D2D is offline   Reply With Quote
Old 11-10-2007, 03:48 PM   #7 (permalink)
Yeah there is a discrepancy in the mileage. I looked in the owners manual but could not find anything about it. I did have my neighbor (who has an OBD) run the codes but nothing showed. Is the blinking odometer just a service reminder? Thanks.
Old 11-11-2007, 01:31 AM   #8 (permalink)
No,something has suffered a glitch,also I dont think your friends OBD kit will get into the instrument pack unless its one of the very latest ones,most will only read powertrain codes.To get into the instrument pack or BCU it will probably need Testbook or Autologic/Rovacom.
Old 11-12-2007, 07:49 AM   #9 (permalink)
What does it cost for the dealer to hook up to the Test Book? Also, out of curiosity, why would the odometer show a different mileage than actual? I was told when I bought it that it had 136k and the odo shows 30k.
Old 11-12-2007, 07:55 AM   #10 (permalink)
I wouldn't worry about the cost, which could easily be in the mid$150 range, you need to get your mileage issue corrected along with the blinks.
