Old 01-19-2007, 12:15 AM   #1 (permalink)
Default Will the christmas trees prevent passing emissions?
Hi I am new owner of a used 01 disco II.
I am about to have the car smogged and would like to know if
they will not pass with with the ABS,HDC,and traction control light on.
If so, how would i go about clearing them?
Thanks in advance
jommani2000 is offline   Reply With Quote
Old 01-19-2007, 12:26 AM   #2 (permalink)
saharatj98's Avatar
I'm not a Rover expert, but, I do not know how functions such as ABS(brakes) HDC(brakes) and traction control (brakes) would have anything to do with how your engine runs and the ability to pass emissions. HDC does utilize controls for the transmission and engine to optimize (engine braking) using the compression of the engine in a low gear to slow down the vehicle. I would not worry about the test. I would be looking at the cause of your warnings however. I would be willing to bet a broken ABS sensor wire could cause a chain reaction of all of these systems to error out.
Chuck
2003 Disco SE7
Redmond, Washington
2005 BMW M3 E46Fanatics.com BMWCCA
1985 Porsche 944 Pelicanparts PCA
1984 Volkswagen Rabbit GTI VWvortex.com
saharatj98 is offline   Reply With Quote
Old 01-19-2007, 04:38 AM   #3 (permalink)
Roverhound's Avatar
To get them cleared you need to go to someone with a computer that has the ability to read the SLABS system faults. That would be someone with either Rovacom, T4 and the other I can't recall now.
Get it read and find the problem. Then go from there.
It just doesn't matter.
Old 01-19-2007, 05:28 AM   #4 (permalink)
not it shouldnt but if you pull the fuse or drive around long enough I mean months then a rough road code will be stored in the ecu and perhaps it could fail.
Old 01-19-2007, 04:00 PM   #5 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
beware most smog shops are so stupid, any light and they might fail you, even if they have no clue as to what the light means.
RudemanRB is offline   Reply With Quote
