Seems like I spoke too soon when I said that my Disco is running perfrect.
I drove approximatly 4km and stopped at the shop and my disco will not start. The truck went perfect untill I shut her down and went into the shop and tried to restart.
I do have fuel in
The starter is turning the engine over.
I took out one of the spark plugs and there is no spark while cranking over.
The battery is still strong.
Truck has 140000 miles on.
Manual transmission.
Could the alternator be causing this: (It has never been serviced.)
Could it be the fuel pump? (If so why no spark)
What should I check and how should I check it.
I will appreciate any help.
99 Discovery 2 XS V8
Coils Replaced Air Bags
Mod on Front Bumper
Dastek Unichip
BFG All-Terrain Tyres
its a cheap part ($60 usd) that fails quite often. Just replace it. To the best of my knowledge there is not any way to test it, but maybe Mike or someone else can give their thoughts here.
If it is the crank sensor, and this is a common issue, it may restart after sitting for a couple hours.
Yes, you can test the voltage signal from the crank sensor with either an OHM meter or a good scanner.
Thanks for replying, I stepped out for awhile and I know he is getting worried down there in Beautiful S. Africa.
I replaced the Crankshaft Position Sensor lastnight and the truck fired up perfectly. I drove the truck to work and it seems this all is well. I would assume that there would be no need to get it onto Testbook to have it set.
I really hope that this is the last of my troubles.
Thank You For The Assistance All Of You Offered.
Mod on Front Bumper
Dastek Unichip
Good JOB! I am glad that was the issue. No testbook needed after install.
I am going to change mine for the heck of it now. I turned the key yesterday and NOTHING... grrrrr I immediately thought CPS. Until I realized my son left the dome light on last night and the batt was dead! Wheeeew!
"I really hope this is the last of my troubles"....you own a disco you will always have troubles!
