Old 12-09-2005, 11:25 AM   #1 (permalink)
Polish and proud of it.
TsiArt's Avatar
Default Windsheald wipers Problem
Ok I noticed this like month ago , but it happend only once , so I figured it was some kind of one time glich .
Well this morning going to work in the snow storm .
I had it set to 'intermediate' the lowest seting .
What happens that the wipers get stuck , like I would have a bad contact somewere to the wiper mottor . and they continue to be stuck untill i get out of 'intermediate' , I can leave them in 'low' and they work fine .
So it would look to me like it's a timing curcuit.
Did anyone had that happen to them ?
BTW it's Disco II .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 01-03-2006, 10:58 AM   #2 (permalink)
TsiArt's Avatar
No one had this problem ?
Old 01-03-2006, 11:27 AM   #3 (permalink)
Otherwise known as STEVE
I had one do that- the dealer replaced the whole motor assembly.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 01-03-2006, 11:29 AM   #4 (permalink)
Sounds like the stop switch inside the wiper motor is beginning to fail. If that is the case, there is no repair, just replacement of the motor. The wiper switch can fail, but it is not very common.
Mike J.
Old 06-26-2008, 06:09 PM   #5 (permalink)
our wipers are doing the same thing. working fine on constant and sticking upon return when on intermittent. any sugestions. how do i access the motor?
matdavies is offline   Reply With Quote
Old 06-27-2008, 05:56 AM   #6 (permalink)
It is the stop or park switch that is failing. This is located in the wiper motor and the wholw wiper motot must be replaced to correct the problem.
