Old 04-07-2008, 05:21 PM   #1 (permalink)
Default Windshield Replacement & W/S Motor Problem
I have two questions... First, I am having my front heated windshield replaced, and the glass company wants to use one manufactured by PGP, rather than the original Plinkington. Is there any reason I should go with one over the other?
Second, the windshield motors have a weird problem where they will not operate when the temperture is below 35'F. If I twist the stalk-mounted switch repeatedly (turning it back and forth, from 'HI' to 'LOW') the wipers will move up slightly each time. When they get about half way up, they then run OK, so long as I don't switch them to intermittent mode. They will park themselves correctly when shut off. After the truck warms up, they work fine in any mode. Any ideas, or can anyone point me to a detailed description of how they work? I have the RAVE CD, but it doesn't describe how the wiper motor work internally, ie: how the park switches work.
2002 Discovery SD; with customized dents!
CurryHook is offline   Reply With Quote
Old 04-07-2008, 09:22 PM   #2 (permalink)
2002 Discovery II SE
My wipers normally dont operate when its cold until the truck is warmed up a bit.
Alak is offline   Reply With Quote
Old 04-12-2008, 05:59 PM   #3 (permalink)
Bumping this topic .... if someone can help. thx
Windshield replacement mod4b Range Rover Classic 6 07-14-2008 06:59 AM
Windshield replacement need some help Madeara Discovery Series II 3 04-17-2006 11:11 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Windshield help!! Figman Discovery Series II 6 10-31-2005 09:17 AM
Windshield Wiper Replacement Figman Discovery Series II 8 09-23-2005 08:42 PM
