Old 08-31-2007, 10:58 AM   #1 (permalink)
Question Windshield Wiper Question
Bought some new wipers at walmart, broken off the factory driver side wiper trying to take it off In looking at the oem wiper compared to walmart special it doesn''t look like its gonna work out, whats everyone else using for wiper replacements and where to get them?
Witzel is offline   Reply With Quote
Old 08-31-2007, 11:01 AM   #2 (permalink)
For a D 2, you can use only Dealer wipers or Sill Blades which are sold by Expedition Exchange. I have a set of Sill blades on and they have done well for the last 3 years, either way, they are expensive.
Old 08-31-2007, 01:28 PM   #3 (permalink)
Roverhound's Avatar
Go to an auto parts store. Auto Zone or Advance auto or the like. Go to the book on a string or the computer thingy and look up Land Rover, 2000, Discovery. Low and behold! You'll find wipers that fit your truck!
Dealer only
It just doesn't matter.
Old 08-31-2007, 01:37 PM   #4 (permalink)
'00 DII Member
auwesman's Avatar
Dealer only
I'm not so sure about that. I've looked at Advanced Autos, Auto Zones, Walmarts, etc. and never found a blade that will fit my D2 at those stores. The guys at Auto Zone told me they don't sell anything that will fit and sent me to the dealer. I bought sill blades and highly recommend them. I guess you may get lucky and find some at auto zone that fit, but I have had no luck.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 08-31-2007, 02:05 PM   #5 (permalink)
Roverhound's Avatar
It's a narrow blade. Common for BMW's I get mine at Advance no problems.
Old 08-31-2007, 03:00 PM   #6 (permalink)
Roverhound's Avatar
Anco W22R.
Now you don't even have to go to the book on a string or computer thingy. I did it for you!
Old 09-01-2007, 11:00 AM   #7 (permalink)
boca disco's Avatar
on my 04 DII i bought blade refills from auto zone, bent the clips back that held the factory blades on the original wiper, pulled old blade inserts out put new ones in then bent clips back to normal. Wipers work just as good as the $50 pair i bought from LR last time except these only cost me $5
boca disco is offline   Reply With Quote
Old 09-03-2007, 02:07 PM   #8 (permalink)
Bahamian01's Avatar
I usually change blades only. I use TRICO 45205, and they fit OK. Give'em a try...
Bahamian01 is offline   Reply With Quote
Old 09-03-2007, 03:16 PM   #9 (permalink)
'99 Disco II
wimp's Avatar
Not sure if you guys agree, but the DII wipers suck!
crappy spring tension...At their best, they are the worst wipers I have had on any car! Period!
I bought new Disco I arms. They work great! Refill the arms with blades that are 2" larger than the Disco I calls for.
'99 Disco II
ACE / 2" OME lift
245 75 R16 Greatyear MT/R's
wimp is offline   Reply With Quote
Old 12-17-2008, 09:29 AM   #10 (permalink)
Yep, after buying sprees at autozone and walmart I can attest that all of them were wider than the 99 Disco arm will accept. Guy at autozone said they don't carry the ones for the rover and that it was dealer only...anyway I guess I could replace the blade but I like getting the whole damned thing - maybe I'll try the expedition site Mike noted.
OJ's DNA is offline   Reply With Quote
Old 12-17-2008, 10:40 AM   #11 (permalink)
A few years ago, I got some replacements at Pep Boys that fit well. Unfortunately, I don't remember the brand.
raoul76 is offline   Reply With Quote
Old 12-17-2008, 12:05 PM   #12 (permalink)
I've used those 'cut to fit' blade refills....they worked fine for a while...and they were only $4 or so....but I got tired of the wipers missing stuff because they had really weak springs or whatever....i bought a set of D1 arms and bolted them up, now I can get wiper refills at many fine auto retailers
BamaDisco03 is offline   Reply With Quote
Old 12-19-2008, 10:15 AM   #13 (permalink)
DINOKLR's Avatar
You may want to check Atlantic British or Rovers North. I forget which one exactly (thinking Rovers North), but for sure one does have a couple of options for you. They offer the silliblades and also have a kit with siliblades that includes new "standard" wiper arms that you can get to accept any normal wiperblade you may pick up from any autoparts store.
DINOKLR is offline   Reply With Quote
Old 12-19-2008, 01:36 PM   #14 (permalink)
'02 Disco II
maggers's Avatar
I highly recommend the Sill blades. That and a "heated seats special" upgrade from Atlantic British were the first two things I did to my Disco... They still perform like they did the day I installed them which was in 2006, around July.
maggers is offline   Reply With Quote
Old 12-20-2008, 08:49 AM   #15 (permalink)
I went to Walmart and priced some blades, for my 2002 Disco II. They told me Rain-X 21inch should fit my Disco. Do you guys think they are correct or what?
drice23 is offline   Reply With Quote
