Old 01-10-2007, 09:46 PM   #1 (permalink)
Smile Windshield Wipers
Hey... I was just wondering if there are any recommended brand or type of windshield wipers?? Where should I get them?
johnnybob06 is offline   Reply With Quote
Old 01-10-2007, 09:59 PM   #2 (permalink)
I am using the factory blades on front and back now, but in a pinch I have used the top of the line wipers from Walmart--maybe Bosch? They don't fit the arms, but if you pry open the clips on the mounts and slide out the rubber blade, it will slide into the old rover blade mount. Pinch the clips closed and put them back on the arms. It's a small bit of labor, but it's only about $12 and you don't have to wait for them to be shipped. Last time I did this, I had already ordered new factory wipers, but ended up using the Walmart rigs for a year and they worked fine. I just replaced them about a month ago.
zoomblur is offline   Reply With Quote
Old 01-10-2007, 09:59 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
DII right? What I have seen a lot of people do is put DI arms on so they can go to any auto store...not just special order! Talk to Keptin on this site!!
I like Bosch...but with the snow/ice ANCO winterblades are getting the work done!
Old 01-10-2007, 10:14 PM   #4 (permalink)
how much do the factory blades cost?
Old 01-10-2007, 10:41 PM   #5 (permalink)
Choqiees's Avatar
get SilBlade...
https://www.expeditionexchange.com/silblade/
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 01-11-2007, 05:08 AM   #6 (permalink)
I agree, go with the Sil Blades, I bought some E.E, 2 years ago and they are holding up well.
Old 01-11-2007, 06:43 AM   #7 (permalink)
OkieRover's Avatar
Gallery: 3
SilBlades FOR THE WIN Alex.
Old 01-11-2007, 08:33 AM   #8 (permalink)
Chicago Rover66's Avatar
Thumbs up
SILBLADES, going on 2 years now on the fronts, the rear window blades from the factory suck.
2001 D2 SE7
Chicago Rover66 is offline   Reply With Quote
Old 01-11-2007, 11:31 AM   #9 (permalink)
Ok, so one last question... do the SilBlade's replace just the wiper blade or does it replace the arm as well??
Old 01-11-2007, 11:37 AM   #10 (permalink)
OkieRover's Avatar
Gallery: 3
The blade goes on the end of the arm. You'll understand better when you see the pictures.
Old 01-11-2007, 01:38 PM   #11 (permalink)
Choqiees's Avatar
just the blade..
Old 01-12-2007, 01:14 PM   #12 (permalink)
RoverChic's Avatar
X2! I have a set on my other D2. I also like the PIAA as well. You have to have the D1 wiper arms though to use the PIAA blades. Shop around on the Silblades...they can be had for a lot less on a few other sites!
2006 Range Rover Sport HSE Rimini Red
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
Old 01-18-2007, 12:25 PM   #13 (permalink)
What about winter blades???? anyone have any they like??
6cuda6 is offline   Reply With Quote
Old 01-18-2007, 05:16 PM   #14 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
Man I love living in Southern Californina.
Rain what's that?
RudemanRB is offline   Reply With Quote
Old 01-22-2007, 08:32 AM   #15 (permalink)
Jason
jase7678's Avatar
I was going to order some SilBlades yesterday but after an ice storm I had to do something quicker as my passenger side blade was shreaded. I bought a 21" refill and fitted this. I started going the route discussed above but this was proving too difficult as the blade was freezing and wet. Anyway, if you pull the blade rubber on its own, it comes away from the metal retaining / strengthening strips inside the blade. When the blade has been completely peeled away, these strips naturally fall out. To put the new blade in was a case of twisting the rubber on the new blade to locate it in the clamps. Conclusions, opening and closing of clamps mentioned above is unnecessary. I did have to lop a good chunk of the blade off the end as it was too long, but a very satisfactory solution none the less.
jase7678 is offline   Reply With Quote
