My dang wipers, the more I use them, get farther away from the windshield. When I'm driving in the snow it's terrible, might as well not even have them on. The wipers end up off the windshield.
I'm fairly sure this is caused by a weakened wiper spring. Does or has anyone changed these out? or have any part # I could bum from them to save me some time? I haven't had much luck finding part #'s for these on the net. Thanks |
#2 (permalink) | |
i converted over to the d1 arms. they have a better spring and you can find wiper blade refills at any auto store, got mine from atlantic british (Atlantic British - Land Rover Parts & Accessories | Range Rover, Discovery, LR3, LR2, Defender, Freelander and Land Rover Series Parts & Accessories). WIPER ARM - FRONT Item: PRC8236 Fits: Discovery I | '94 - '99 _________________ landrovergeek 99 D2 kinversand Miami Valley Land Rover Society www.mvlrs.com |
Back in a Series LR after 25 years :-)
Not to hi-jack, but.....
![]() My D2 blades are on their last legs so I picked up a a complete set of 3 D1 wiper arms of eBay. Question, do I get the D2 length or the length for the D1? ![]() Steve
Back in a LR after 25 years!!! 71 Series IIa 88 01 D2 "BackInA88" on all the other LR forums (Sign up here first and couldn't think of a good handle at the time! )
Depends...if the wipers attachment points are at the same distance ( just compare them side to side) as the original D2 arms, then go with D2 lenght. But if they are different, then go with D1 lenght, otherwise the wipers might hit the windshield frame in their operation.
#5 (permalink) | |
Exactly why I am asking. ![]() I could figure it out myself but this being a common swap I figured someone would know the correct size. ![]() I guess I will play around with some of the spare blades I have in the basement and figure out the correct length. ![]() Thanks, Steve
'99 Disco II
you use the d2 length
I did the conversion and used the dI length by mistake it was ok, but you don't cover enough windshield Once the DII length is on, it is awesome! I will try even longer next time. I beleive the driver's side could stand to be an extra inch longer (1/2" each end of the blade) ![]()
'99 Disco II ACE / 2" OME lift 245 75 R16 Greatyear MT/R's
'99 Disco II
btw
Use the Bosch Icon blades. Expensive, but AWESOME!!! kick the crap out of all those, so called "winter" blades. my 2 cents
#8 (permalink) | |
#9 (permalink) |
according to Expedition exchange, you're supposed to the the D1 length, which is 18 inches. Maybe somebody with more some text books handy can help out, but I seem to remember that a wiper arm is supposed to apply 1 lb of force per inch of wiper blade. Using a blade that's too long will decrease the effectiveness of said force.
#10 (permalink) |
'99 Disco II
Kdamericano:
I am speaking from experience, I had the DI length, then switched to the DII length. use the longer length with the ICON blades you won't be sorry. Plenty of pressure. awesome setup!
#11 (permalink) |
I was speaking from experience too, as I have the Silblade D1 blades that come with the kit from EE. The coverage is slightly less, but I can still see fine. The D1 arms are a little longer than the DII's, and the DII windshield is only about an 1" taller than the D1, so the perfect blade is probably somewhere in the middle.
Really, it doesn't matter much though. As long as they work. |
| Thread Tools | |
| Display Modes | |
| Wiper motor question | Grid_Lock | Discovery Series I | 0 | 10-13-2007 04:21 AM |
| Windshield Wiper Question | Witzel | Discovery Series II | 8 | 09-03-2007 03:16 PM |
| Wiper Unit? | Jayce | Series Land Rovers | 6 | 06-10-2005 12:22 AM |
| Rear window sprayer??? | pzwerner | Discovery Series I | 1 | 01-30-2005 12:38 PM |
| Problem with the window wipers | JP-NORWAY | Defender | 2 | 09-02-2004 10:06 PM |
