I'm going on week three of my life as a Disco owner. The first (slowest) speed on my D2 wipers are delayed by about 30 seconds before they begin to wipe. The fastest speed does not seem to have a consistent formula as to when they will begin to wipe....but are delayed also. The middle speed works right away.
![]() Any suggestions....is this the wiper motor going bad or something with the switch? Thanks!
2003 Disco II SE in Java Black |
The slow blinker thing is because of the turn signal switch. If you pull it out, take it apart, clean everything, and put it back together with a good di-electric grease, you should be fine. Or, if you're lazy, you can just order a new one.
It's been a while, but as I recall, you pull off the cover around the steering wheel (3 screws or so), and then the whole assembly just unscrews (maybe 4 screws sounds right). It looks like this
http://www.roverparts.com/product/img/Icn/stc4017.jpg |
#9 (permalink) |
take that out, then take apart the mechanism (that rectangle-looking thing attached to the lever), you'll need some q-tips and alcohol to clean off all those connections inside there, apply some dielectric grease, and reassemble -OR-, just order a new one. You could also replace with a used one, but I would make sure it was out of a newer (say 03-04) Disco so you don't have the same problem again.
| Thread Tools | |
| Display Modes | |
| Windsheald wipers Problem | TsiArt | Discovery Series II | 5 | 06-27-2008 05:56 AM |
| windshield wipers don't work | jedi | Discovery Series II | 1 | 12-06-2007 05:49 AM |
| Windshield Wipers | johnnybob06 | Discovery Series II | 14 | 01-22-2007 08:32 AM |
| wipers won't park | lou | Discovery Series I | 7 | 12-25-2004 02:32 PM |
| Problem with the window wipers | JP-NORWAY | Defender | 2 | 09-02-2004 10:06 PM |
