I burnd 3 of the Disco II iso images to Cd's on 2 different burners. Neither computer copuld read the CD I have not had this problem with these burners before??? I have made many a bootable CD on here. The burn finishes w/o error but whe I try to explore the files, nothing is there. O % used and 0%free.
Any Idea what am I doing wrong????
Thanks
06 Disco II Trail 75000
99 Disco II 220000 and going strong
2011 Benz C class
Trek 720 Cross Terrain Bicycle
RAVE download
No need to burn to CD or anything, it's just a PDF file you open. Unzip the file to a folder on your C: and run from there.
but with that version, you don't get the wiring schematics, connector views/locations or pin out locations (pos,neg./ what ever else). also it has the vehicle hand book for 00 or 01 and 03 models.
another advantage is to the other version is the English/English export (theirs and ours, NAS).
Thanks
when i 1st did this a couple of years ago. i couldn't get it to work either. earlier this year i tried again, and it worked. but cannot remember if i did anything different or not. i'll get back to ya on it.
Oh I thought the cd was something different since the iso was 700meg and the PDF is 35 meg
That clears that up
I was trying to find if there is a fuse associated with the transfer box high to low interlock solonoid. I have not found one.
Is there one?
Thanks again
2011 Benz C class
I couln't find anything on the hi to low solonoid either but since it's electrical I thought there migh be something.
As far as on call I am there also, I really appreciate the time you spend here helping. It must be a real love of the Rovers.
Tomorrow I will take out the center console of my Disco II for the first time. I'm a bit nervous but there is good info here. So, maybe it will go OK. We will need low range out west next month. I just wish I had the time to put the diff lock shifter before we leave.
Thanks again Half
2011 Benz C class
A couple of things, First I tried to burn the CD using standard software with no help (twice), I down loaded Nero (Free Trial - Custom install for just the burner portion), and the CD(s) work fine now.
There is a relay on page 25.1 TRANSFER GEARBOX (N121)
SOLENOID-INTERLOCK-of the WDM with a 1 amp fuse. it is inline with Header 1002 (K109). If you shoot me your email I will send you a PDF of the page
Thx, I'm downloading it now to check it out.
For those that are having hassles reading it, go download 7zip (7-Zip) (it's free) and then use it to open the ISO file. You can extract the contents to your C: drive and there's no need for burning to CD.
If you want to burn to CD use ISO Recorder (ISO Recorder v 2) - it's a simple quick and easy method if you are not familiar with other CD burning software.
Does anyone know of another location to download this? Or is The Green Oval down for maintenance. I've been trying to get there but the Green-Oval.com seems to be down.
I'm in real need of a wiring diagram. The heater died on a 2000 Disco II. I've narrowed the trouble down to the hot wire (brown and red wire) going to the fan assembly. I've got power to the fuse, power to the relay. From there I need a diagram. The ground wire reads good.
In the "electrical library" of RAVE for Discovery II, it has diagrams, photos and connectors...
