Old 11-24-2007, 11:21 PM   #1 (permalink)
Grid_Lock's Avatar
Default wtf is going on with my tail lights v. help
So someone told me that one of my break lights was out, so i just went out and checked it. it was a lot worse than that. heres whats going on
the lights have 3 sections, right?
bulb on top (running lights?)
bulb in middle (break lights?)
bulb on bottom (reverse lights.)
when lights are on:
left side: bulb on top is glowing red
right side: bulb on top is glowing red
when breaks are on:
left side: bulb on top goes out, middle bulb is very dimly lit, reverse light is dimly lit
right side: bulb on top gets mildly brighter, bulb in middle is still out, reverse light is dimly lit
when in reverse:
left side: running light is on
right side: running light is on, reverse light is on - and VERY bright
WTF is going on with my rover?!??!
blinkers are both bumper fixtures, as are the rear fog lights.
Grid_Lock is offline   Reply With Quote
Old 11-25-2007, 02:35 AM   #2 (permalink)
Sounds like it may be an earth problem. or at least part of the problem. if the earth to the chassis is lifted or high resistance the current will backfeed through the earth on other globes on the same light fitting or circuit. instead of dropping 12 volts across one filament, the voltage goes across 2 globes thereby dropping 6v across each (Hence the dim glow on each globe. i would recommend checking the earths first and see what problems are left after that. it may fix them all or show different symptoms which will make it easier to find. on the other hand it might do nothing at all. Electrons have a habit of doing strange things sometimes, even to the point of appearing to defy Ohms Law.
Cheers
Baldrick is offline   Reply With Quote
Old 11-25-2007, 07:31 AM   #3 (permalink)
Grid_Lock's Avatar
Cheers
Alright. Thanks for the advice. I'll see what i can find.
Old 11-25-2007, 03:25 PM   #4 (permalink)
'00 DII Member
auwesman's Avatar
What year is your Rover? My '00 has two on the top for when the lights are on. Sometimes if one light burns out others "kick in" to compensate so you could have a bulb here and there out.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Rear Tail Lights & Break Lights cgaulding Discovery Series I 2 06-17-2006 10:46 AM
FS: 2000 LR DIscovery Tail lights ibjettin Land Rover Parts and Accessories 4 03-08-2006 09:25 PM
Upgrading DII tail lamp nighttime running lights keptin Discovery Series II 6 12-29-2005 02:46 PM
2002 Disco Tail Lights DiscoBoi2002 Land Rover Parts and Accessories 1 10-13-2005 08:17 PM
Hella 500 lights BIRD Discovery Series II 9 08-24-2005 04:31 PM
