xyz switch - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 08-09-2011, 01:33 PM Thread Starter
Quoted: 0 Post(s)
xyz switch
I have a 1999 disco II. My wife was driving it (first mistake). She said she was at a store, finished up and the truck shifted hard into drive. She got to her next appointment and the truck would not go into park. She tried starting it and it went into park but now will not come out of park. It will not start. I checked the battery and it is good. Just in case I took a brand new battery along and put it in and have the same problem. I checked the brake switch on the pedal and still nothing. I checked the brake lights and there are none. Could it be the XYZ switch? I thought it might be the starter, but because it will not come out of park I guessed that was not the problem. Where should I start? I called the dealership and they said it sounds like the xyz but it would cost about $800.00 to test it.
help!!
milwlandrover is offline
post #2 of 8 (permalink) Old 08-09-2011, 02:59 PM
Quoted: 0 Post(s)
On my 2003, it turned out to be the brake light switch that caused the stuck in park problem.
GuyD is offline
post #3 of 8 (permalink) Old 08-09-2011, 03:47 PM
DoggFather's Avatar
Quoted: 1 Post(s)
I also was unable to take the car out of park. xyz was the culprit in my case.
DoggFather is offline
post #4 of 8 (permalink) Old 08-09-2011, 05:01 PM
Quoted: 0 Post(s)
I don't believe the xyz switch would affect your brake lights. I would recheck your brake switch.
chrissai is offline
post #5 of 8 (permalink) Old 08-10-2011, 05:10 AM Thread Starter
Quoted: 0 Post(s)
the switch
I have the original switch and a replacement. How do i check them? Am I just looking for continuity in the 'closed' position and non-continuity in 'open'?
post #6 of 8 (permalink) Old 08-10-2011, 08:44 PM
beecoach's Avatar
Quoted: 0 Post(s)
If you have the replacement, put it in, 5 min job.
2000
beecoach is offline
post #7 of 8 (permalink) Old 08-11-2011, 01:42 PM Thread Starter
Quoted: 0 Post(s)
xyz
I replaced the switch the other day and had the same failure. no brake lights and it will not shift out of park and will not start. I thought it might be the imobilizer in the remote so I tried locking the doors twice and opening it, but that didn't work. I tried a new battery to no avail. I tested the switch for continutity and it seems good. Perhaps the starter? would that lock me into park?
post #8 of 8 (permalink) Old 10-22-2011, 01:03 PM Thread Starter
Quoted: 0 Post(s)
neutral safety switch
Just to close this out. Thanks for all your help. I found a neutral safety switch on ebay for $5.00 plus shipping and installed it. The transmission now engages. It still needs to be adjusted. I think you just put it in neutral and adjust the shaft on the cable. correct?
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Testing a XYZ switch???? Clark Discovery Series II 0 06-21-2011 01:13 PM
XYZ Swith location clayrobinson Discovery Series II 7 06-05-2011 06:38 AM
XYZ switch bad - or in need of adjustment? krigsmakten Discovery Series II 5 12-23-2010 12:56 PM
XYZ Switch problem, No D or N!! eroc disco Discovery Series II 4 08-12-2009 07:58 PM
Replacing the XYZ Switch, P0705 tex599 Discovery Series II 1 11-04-2008 04:39 PM
You may post new threads
You may post replies
