Not sure about the wiring. Keep me posted if you decide to have it installed. I'm curious as to whether or not they will install it as "always hot". the outlet in my 06 only works when the key is turned. i understand its a safety feature that won't allow the battery to be drained should you forget to unplug something, but it's a bit of a hassle when you are trying to work back there. I use an inverter, compressor, and other little devices when I'm camping and its a little annoying to have to turn the key each time...
