Old 11-09-2004, 09:06 AM   #1 (permalink)
Cool 2000 Discovery, Salty Dog
I have a deposit on a 2000 discovery II and was wondering, before I go pay the balance. Is there anything I really need to check before I drive off the lot. It has 101k miles and "NO ONE" will write a good warranty on anything with over 100k. I got the price down below trade in according to the NADA guides. So I'm kind of Leary.
Choke
Choke is offline   Reply With Quote
Old 11-09-2004, 09:51 AM   #2 (permalink)
If you are concerned, and you should be, ask the seller to let you take it to another shop for a pre purchase inspection.
Good luck and have fun.
Mike J.
Old 11-09-2004, 10:28 AM   #3 (permalink)
Default i agree
i agree with disco mike there are so many things that could b wrong. i remember 2000 had a lot of cooling syst problems: radiators, intake gaskets, hoses, and even the typical waterpump prob. also 99 was only a half year 4 the new bosch management syst so i still consider 2000 first year 4 disco II
rovertech is offline   Reply With Quote
Old 11-12-2004, 07:57 AM   #4 (permalink)
I strongly agree with Mike and rovertech,but in case you are not allowed to take the car to another shop for a "second opinion" here are some basic pinpoints in no specific order except for the first one :
1.Take a trip to the lot wearing a pair of old jeans and a "not so good condition" shirt...reason? you will be reaching underneath the truck looking for leaks or other irregularities.
2.While the engine at idle,look for leaks underneath and viewing the vehicle from the front.Also look for leaks in the engine compartment,if the vehicle was "just washed and detailed" drive it up to a dry spot.
3.When you shut off the engine go to the front of the vehicle and see if you smell coolant.If you do,this is a common happening on Discoverys,which could be a leaking radiator,lines,hoses,or worse than that,head and /or intake manifold gaskets.All this is fixable,but could be expensive if you don't do it by your own or through an independent reliable shop.Believe me,I just went through a refurbishing of the upper part of the engine by my local LR dealer on my Disco with new gaskets,head bolts,idler pulley,exhaust gaskets,etc replaced...the charge? a bit over $2,000 bucks,as I don't have a local independent and RELIABLE repair shop around where I live.As I said in another thread:If you can't find a reputable shop around your area,go to the dealer,as they might be expensive,but will stand behind their work and warranty,rather than jumping from shop to shop misdiagnosing the problem and probably spending more money than if taken originally to the dealer.
4.Look underneath the vehicle behind the back wheels and look for grease leaks around the brake rotor area,also look for both front and back differential leaks.
5.Discoveries have almost a dash indicator light per system,so look for abnormalities,particularly the amber "service engine soon",abs,and srs/airbag lights.
6.Check if the truck misses at idle,could be a problem in the MAF sensor,O2 sensors,or just a dirty air cleaner in need of replacement.All these parts could be bought through any parts supplier online and could be replaced in your garage,driveway,or backyard;nothing big though;but always pretending that it IS a big issue in front of the salesman,so you can see if he or she lowers the price a bit for that reason .
Parts suppliers are available online with better and really competitive prices than dealers,so if you don't find anything compromising with this truck you placed a deposit on,I would say go for it!
I think that you could have a general idea of what to look for now.also welcome to the LR world!!!
Carlos
Carlos is offline   Reply With Quote
Old 11-15-2004, 10:39 AM   #5 (permalink)
Thanks to all for the input. The Disco II is at home now, I'm thinking she hadn't been in a garage in a while. I though I saw a smile when she parked on the carpet and the door closed.
Things where ok, a few small wet area nothing leaking more then a drip of oil the entire ride. I did a really good check and found a few lights out. the windshield needs to be replace too. 5 chips and a small crack. but for the price. I'm very happy. I like to clean my vehicles too, good thing, because nothing looks as nice as BLACK when it's clean. at low speeds the gear box noise seems loud but really seems to smooth out the fast you go. Is this normal.
Choke
Old 11-15-2004, 12:19 PM   #6 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Talking Nothing a change in fluids could not cure....
the gears will sound a bit after 20 mph but nothing a fluids change won't cure. The gearbox does make some noise but it is part and parcel of owning a REAL LandRover!
Congratulations and atta BOY!!
I have a 1997 Black Discovery and the tranny fluid came out black the first time. Just do the oil and fluid changes, start the winterizing, and get ready for the most fun winter you are going to have.
I was over at the local beach yesterday and brought my best friend. He Liked the Discovery, especially with the rug rats, and then I let him drive it. Fell in love with it. Splashed puddles like crazy. Made him clean it up.
