Old 06-05-2007, 08:50 PM   #1 (permalink)
Blyzard
LR3dirver4ever's Avatar
Default Air suspension lift kit?
is their such thing as a lift kit for a vehicle that has air suspension
what i am trying to say it their a lift that can be put on the LR3 ware the hight will say hypothetically start at the off road height of the regular suspension on the LR3 and be raised another 3 or 4 inches?
LR3dirver4ever is offline   Reply With Quote
Old 06-05-2007, 09:54 PM   #2 (permalink)
you might want to shop around for larger capacity airbags so when they inflate they give you extra lift
cartm58 is offline   Reply With Quote
Old 06-05-2007, 10:14 PM   #3 (permalink)
Thor's Avatar
A lift on an Independent suspension rig does bad things! Poor angles on the joints and if you imagine rotating the arm around the suspension mount you'll be way to far outside design limits you'd be riding on the outside of the tires. You'd be better off doing a live axle swap! Or a full LR swap to a RR1.
Todd
Carpe Rangius Roverum
