» Sponsors
» Sponsors
Old 09-14-2009, 09:23 AM   #1 (permalink)
Default Brake Job
Sorry to beat a dead horse.
I have an '05 and the brake light just came on and I knew it was going to happen soon. Dealer told me I needed new pads and rotors. I have 53k and the 2nd owner, so I do not know all the history. I know its cheaper to do the labor myself, however I am not a highly skilled wrencher. Dealer has quoted me $1600. Is there anywhere in the DC Metro area that anyone can recommend to get a 2nd look? Any help is appreciated.
Brian
DCLR3 is offline   Reply With Quote
Old 09-14-2009, 03:41 PM   #2 (permalink)
Does it have an Ipod thingey?
lexlaws's Avatar
Jeez... I was just quoted $1180 for the same brake job from my dealer here in California... They must do some extra special brake work in DC...
LR3
Mini Cooper
1098
Sport 1000S
lexlaws is offline   Reply With Quote
Old 09-14-2009, 08:01 PM   #3 (permalink)
drzjoint's Avatar
Gallery: 5
ya, anywhere but the dealer. You can do it yourself for around 300. try an independent. Brakes are simple.
05 LR3 - 7 SE BLUE V8 aka
THE JUGGERNAUT BITCH"
drzjoint is offline   Reply With Quote
Old 09-15-2009, 03:09 PM   #4 (permalink)
My front brakes just went and I was faced with the same problem. Dealer quoted me $890 for one rotor and pads on both sides (front only).
Instead I bought the parts from Atlantic British and had a local shop do the work. (I live in Hampstead MD, close, but probably not worth driving up here when you should be able to get it done locally)
I paid $285 for the parts, which was 2 rotors, front brake pad kit and brake sensor. All OEM, land rover parts.
(Since it wasn't much more I just did both rotors)
Install was $110.
So total bill was less then $400 and everything came out great.
granger is offline   Reply With Quote
Old 09-24-2009, 08:00 AM   #5 (permalink)
Beta testing www.discogirl4x4.com
DiscoDream2's Avatar
Install was $110.
For sure...buy the parts - Get the right stuff! AB is a good place to start.
Land Rover - Parts, Accessories and Information
Don't get crap parts - you will regret it. Save on labor, if you don't do it yourself find a guy on Craig's list that is familliiar with your vehical.
1999 DII ~ ALPINE Edition
@>---^--- Discogirl4x4.com IS READY - COME VISIT! - Beta Version
Project DII:
New bumper cover w/trim, 2" lift, Bottorf Sliders, marker light, custom hood blackout, install DI CDL linkage, TW propshaft, diff guard-rear, mud plugs, Hi-Lift.
Completed
Head gaskets, synthetic oil, MAFS, coil pack, wires, alternator, tensioner pully, serp belt, PAS, fuel pump, 02/16" rims, 285/75/16 BFG KO, OE brush guard, wilderness roof rack, safari tail light guards, OE ladder, NATO fuel can, stereo upgrade, way cool oil gauge, Hella lights x6, CB radio, two rear trail/work lights.
DiscoDream2 is offline   Reply With Quote
Old 09-25-2009, 05:34 PM   #6 (permalink)
BadBonezBJ's Avatar
Yeah, what he said.... Don't cut corners on parts, brakes are the most important safety feature on the car. Cheapo parts tend to fail when you need them most. Just my 2 cents on brakes.
BJ
'06 Land Rover LR3 SE 4.0L V6
Java Black, 7 Passenger
Purchased 6/12/2009, 18,856 Miles, Stock
ADDED:
OEM Land Rover Brush Bar w/light mount brackets
OEM Side Protector Molding
OEM Sunroof Air Deflector
Surco Urban Roof Rack - (off vehicle)
EGR Headlight Lens Protector
EGR Hood Protector
eBay Dash Trim Kit
WheelSkins Two-Tone Lace-up Steering Wheel Cover
TODCO's Adj. Height Rod Kit @ -8mm
RoadkillCustom.com's 1.30" Wheel Spacers - (1 pair)
Fuzion XTI 285/60-18 All Terrain Tires
BadBonezBJ is offline   Reply With Quote
Old 09-26-2009, 09:02 AM   #7 (permalink)
I just did my full front/rear brakes/rotors all the way around on my '06 LR3, got everything from AtlanticBritish and did the entire job for $300. The OEM stull was $500, but I've been happy with the OEM rotors and Ferodo pads. It's really not a bad job if you want to tackle it yourself, there's a good step-by-step on this other forum for the rears (fronts are just about the same): Brake replacement - Page 2 - Land Rover and Range Rover Forums
Hope this helps! PS - I'm in the Virginia area outside DC if you need any help.
nathanwind is offline   Reply With Quote
Old 09-28-2009, 07:38 AM   #8 (permalink)
thanks for all the help. Next time I will def order the kit from AB. I was in a time crunch so I wasnt able to do that. Sucked it up and took it to a local british shop, got killed on parts. They used the same stuff from AB and it was about double the price.
Old 10-12-2009, 03:57 PM   #9 (permalink)
does the brake code light on the dash reset automatically when you swap the sensors or is there a trick to it?
h2oland is offline   Reply With Quote
Old 10-13-2009, 12:34 PM   #10 (permalink)
Default front pads
i plan on having an indy do it too........my only question/dilemma is whether I get original LR pads or go to Atl Brit (or some other place) for aftermarket pads............are the OEM's better?
THX
The Rover is offline   Reply With Quote
What should I have done during maintenance? appstatedisco Discovery Series I 6 08-04-2009 08:44 PM
Help!!! Brake locks up Emperorbilius Freelander / LR2 0 04-24-2009 11:32 AM
[D2] Service Intervals rmuller Tech & DIY 1 05-10-2007 10:11 PM
Where can I get... johnnybob06 Discovery Series II 7 02-21-2007 02:44 PM
Brake Squeal Discussion 01001010 Discovery Series I 4 11-08-2006 07:19 AM
