Old 08-27-2008, 01:57 PM   #1 (permalink)
troverman's Avatar
Default CD / Eject Issue
The 6CD changer in 2005 LR3 will not eject, play, or change--it gives an eject error message. Any ideas? I have heard disconnecting battery will cure this? I can't give a lot of detail--not my vehicle!
Thanks
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 08-28-2008, 11:02 AM   #2 (permalink)
This happened to me; it was a bad CD and the changer gave me an error before I could eject the disk. Then it wouldn't eject it, or any other CDs. I turned the radio off; probably "re-booted" the car and just gave it "time to think." Later on I turned the CD function on, hit the button corresponding to the bad-CD and immediately hit eject. It popped out and I threw the disk away!
Good luck.
HOUM_WA is offline   Reply With Quote
Old 08-29-2008, 08:23 AM   #3 (permalink)
gdlife's Avatar
Default No radio code needed
Don't worry about needing a radio code if you disconnect the battery.Land Rover stopped that in 05'
gdlife is offline   Reply With Quote
Old 09-05-2008, 05:50 AM   #4 (permalink)
troverman's Avatar
Thanks everyone. The vehicle is now ours and 'rebooting' the LR3 cured the CD problem--works great now!
Current:
Also current:
Previous Rovers:
Suggestions please!! Coolant Issue roversne Discovery Series II 2 07-06-2008 01:19 PM
1996 discovery immobilizer issue - need help superderek3 Discovery Series I 1 06-14-2008 08:55 AM
Time is running out for Moab travel management comments jimfoo The Lounge 2 11-13-2007 02:27 PM
Another window issue Disco Truck Discovery Series I 5 03-16-2007 07:41 PM
Got My Issue of Land Rover Lifestyle Magazine WCURoverD90 General Land Rover Discussion 23 01-20-2006 07:14 PM
