» Sponsors
» Sponsors
Old 09-21-2009, 10:21 AM   #1 (permalink)
Default Check Engine Light!
I just pick up a 2007 LR3
the check engine just came on and I have no idea why! the engine in running fine, the manual said if it is flashing immediately stop.
there has to be answer on this site, I did a search but can't find a solution.
I am a newbie to the site and LR3's had 1997 Range Rover which was a lemon I hope i didn't make the same mistake again
Insight anyone?
Bcaese is offline   Reply With Quote
Old 09-21-2009, 10:37 AM   #2 (permalink)
how do I change this?
mbrummal's Avatar
get the codes read at auto zone.
Mason
'00 DII, $G Front Bumper, Hella 4000s w/HIDs, TW Front DS, "Custom" Exhaust work
(from someone on Bimmerforums)
mbrummal is offline   Reply With Quote
Old 09-21-2009, 10:39 AM   #3 (permalink)
ok I'll try that
anyone else know anything??
Old 09-24-2009, 07:18 AM   #4 (permalink)
Beta testing www.discogirl4x4.com
DiscoDream2's Avatar
Originally Posted by Bcaese View Post
ok I'll try that
MB is correct, he knows his stuff, to determine your issue it will be critical to have the vehical scanned with a device. This information will determine the cause of the issue and then a resolution can be identified. Was the light flashing, steady or on then off again?
It's like your LR3 has the sniffles and the Dr. (scan tool) will figure out why, otherwise we would be guessing. Autozone or local auto parts place will scan for free and give you a print-out of the codes and possible resoultions.
Don't freak out, because they may give you 1000 resolutions that seem pretty scary/spendy. Bring those codes back here and these guys will steer you in the right direction.
Do not ignore this light as it will not go away on it's own and everyday you wait is possibly causing harm to your engine or other parts.
I'm sorry this is happening just after you bought it,,, Welcome to the club.
1999 DII ~ ALPINE Edition
@>---^--- Discogirl4x4.com IS READY - COME VISIT! - Beta Version
Project DII:
New bumper cover w/trim, 2" lift, Bottorf Sliders, marker light, custom hood blackout, install DI CDL linkage, TW propshaft, diff guard-rear, mud plugs, Hi-Lift.
Completed
Head gaskets, synthetic oil, MAFS, coil pack, wires, alternator, tensioner pully, serp belt, PAS, fuel pump, 02/16" rims, 285/75/16 BFG KO, OE brush guard, wilderness roof rack, safari tail light guards, OE ladder, NATO fuel can, stereo upgrade, way cool oil gauge, Hella lights x6, CB radio, two rear trail/work lights.
DiscoDream2 is offline   Reply With Quote
Old 10-13-2009, 02:06 PM   #5 (permalink)
Default Codes
My LR3 (2005 V8 HSE) shows (from autozone) codes 316, 303, 305, 308 which indicate cylinder misfiring and crankshaft sensor but the car is running just fine... same gas mileage, power and usual performance... any ideas?
BigC9164 is offline   Reply With Quote
Help! Check Engine Light Comes On & Engine Always Loses Power After Hitting Pot Hole! Jungle Man Discovery Series II 7 09-10-2009 08:50 AM
Speedometer & Check Engine Light Urbanrover Range Rover Classic 4 07-21-2009 05:42 PM
P0125 code thrown but no check engine light. pavel Discovery Series I 3 06-17-2009 06:39 PM
Check Engine Light Blazer7 Freelander / LR2 0 01-25-2009 09:32 PM
97 Disco- check Engine Light on and rough running - loss of power lajilana Discovery Series I 3 08-06-2006 09:03 AM
