Factory Air pump alternative? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 05-12-2010, 12:29 AM Thread Starter
Quoted: 0 Post(s)
Post Factory Air pump alternative?
Has anyone had an aftermarket air pump installed that doesn't overheat so bad? Is the factory design that bad, my firestone pump works like a champ under my 3/4 ton........LR3 pump is goin out I think, gotta do somethin soon.
Crazy_like_the_Fox is offline
post #2 of 3 (permalink) Old 05-16-2010, 08:29 PM Thread Starter
Quoted: 0 Post(s)
Anybody?
I've been told just about any air pump will work, thats its not tied to the cpu in any way, that all it does is fill up the air tank. I'd need to tie in the remote on/off switch somehow and a hot and ground, and I be good to go. Is it really that simple?
post #3 of 3 (permalink) Old 05-24-2010, 12:54 PM
bbyer's Avatar
Quoted: 0 Post(s)
well maybe a Ford pump but ...
There is talk on some of the boards about a Ford pump for the Mark Trucks and the like that is physically mounting wise similar to the pump on the 3. The trouble is that it just seems to be talk.
If there is any problem with the air system, it is that Land Rover is about the only manufacturer to run the compressor at about 250 psig. Everyone else, including the semi trailer guys run at under 150 psig.
That is hence, the basic problem; no one, (including LR), knows how to build a reliable, (lasts at least 4 years until the warrenty runs out), pump that operates at about 250 psig.
Running and storing air in the tank at the high pressure has the advantage that when the truck lifts, it does not do the camel thing like the earlier Range Rovers - lifts first at the front and then the rear. There is sufficient air in the tank to do the lift on all four corners at the same time.
What is interesting is that the air springs still operate at the lower pressures, (about 100 psig), so you do not need much more pressure than that to actually function.
Some are installing a second air tank on the other side of the 3 to add to the stored air volume; with that done, then a lower air pressure compressor is practical, assuming you can override/reroute various software signals between the ECU and the factory compressor.
Name:	LR3 Tank pressure 210 psig.jpg
ID:	25386   Click image for larger version
Name:	LR3 Air Line Routing sketch.jpg
ID:	25387   Click image for larger version
Name:	LR3 Air Suspension Schematic Block diagram.jpg
2005 LR3 HSE 4.4L V8 petrol; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors; LR4 hitch receiver; Wiggs D4 Bluetooth Module; 3 Blink signal light feature; Clock on the Dash; D4 Backup Camera; 2015/16 Nav Data update.
bbyer is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
User Tag List
Linear Mode Linear Mode
Air Suspension Pump open canadianDisco2owner Discovery Series II 2 04-03-2010 12:35 PM
Air Suspension Pump/ Airbag nijones25 Range Rover P38, Mk III and Range Rover Sport 2 05-14-2008 11:36 AM
Does anyone have any history working on factory installed rear air? texaninmass Discovery Series I 2 04-20-2008 05:16 PM
used eas air pump 20$ ebay raid13 Land Rover Parts and Accessories 0 06-16-2007 06:20 PM
Air Suspention pump for sale ASH Land Rover Parts and Accessories 2 10-22-2006 08:20 AM
You may post new threads
You may post replies
