Front floorboard water leak - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 11-09-2011, 07:39 PM Thread Starter
Quoted: 0 Post(s)
I've been searching but most people seem to have clogged sunroof drains, I've already cleaned those out. I'm getting water in the floorboard between the front pillar and the seat on both sides, more so on the drivers side.
Any place in particular to look for?
michicks is offline
post #2 of 6 (permalink) Old 11-10-2011, 10:27 AM
Quoted: 0 Post(s)
What model year is it?
I've had a similar problem in my '06 LR3 (all the gory details in this thread: I seem to have a small lake in my '06 LR3 )
The list of water sources includes:
Sunroof drains being clogged
Sunroof drain lines getting kinked
A leaking windscreen cowl -- especially that nice little dish the passenger side wiper sits in -- often after a windscreen replacement.
The drain tube to the HVAC coming disconnected
And what turned out to be my problem: the A pillar leaking. This was caused by the A pillar being swapped out (by the dealer I bought it from) and the requisite patches not put in place.
You do want to get that fixed and get the carpets and under-carpet insulation dried out as one of the main wiring trunks runs under the passenger-side carpet. Electricity and water don't play well together.
Hugh_Mannity is offline
post #3 of 6 (permalink) Old 11-10-2011, 05:47 PM
bbyer's Avatar
Quoted: 1 Post(s)
Air conditioner drain hoses but doubt it.
One of the files re the link below shows a jpg of the air conditioner drain hose layout.
If your carpet was soaked by the gas pedal or just on the other side of the transmission hump, then I would think that one or both of the AC drain hoses has disconnected itself.
Since the water is instead near the A pillars, then the previous post above is more likely the solution.
DISCO3.CO.UK Photo Gallery - LR3 miscellaneous
2005 LR3 HSE 4.4L V8 petrol; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors; LR4 hitch receiver; Wiggs D4 Bluetooth Module; 3 Blink signal light feature; Clock on the Dash; D4 Backup Camera; 2015/16 Nav Data update.
bbyer is offline
post #4 of 6 (permalink) Old 11-11-2011, 03:34 AM
Quoted: 11 Post(s)
Some things just never change, do they?
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
post #5 of 6 (permalink) Old 11-11-2011, 11:00 AM Thread Starter
Quoted: 0 Post(s)
Forgot to say its an 05' HSE, I'll be tearing into it this weekend or next week thanks for the links.
No kidding P.T. ...
michicks is offline
post #6 of 6 (permalink) Old 11-14-2011, 09:08 AM
Quoted: 0 Post(s)
No kidding P.T. ...
Good luck -- and check the A pillars!
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Water Leak MimiKim Discovery Series II 8 02-03-2010 04:40 PM
Water leak in the floorboard cbwhitley Discovery Series II 3 06-26-2009 07:05 PM
water under pass. side floorboard alabamadisco 03 Discovery Series II 4 05-03-2009 07:44 PM
Water Leak steq184 Freelander / LR2 0 07-20-2008 12:31 PM
floorboard leak on 98 disco theblackhand Discovery Series I 4 06-14-2005 01:48 PM
You may post new threads
You may post replies
