Has anyone taken off the outer A-Pillar on a LR3? - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-10-2012, 07:40 PM   #1 (permalink)
member
SafariDave's Avatar
Default Has anyone taken off the outer A-Pillar on a LR3?
Does it just pop out?
Do I need any tools? Or a way to do it so I don't bend the A-Pillar?
Can anything break besides the clips when I pull it off?
Well it be flushed once I replace it with new clips?
Thanks,
Dave
The City is a Jungle.
2005 LR3/Disco3 SE 4.4 The Rhino
1999 LR Disco II SD 200,900 miles (Sold)
1991 Range Rover Classic (Sold) 'The Turtle'
1988 Range Rover Classic (Sold) 'The Rust Bucket'
SafariDave is offline   Reply With Quote
Old 11-12-2012, 11:22 AM   #2 (permalink)
member
SafariDave's Avatar
I fixed it myself, added new patch and new style clips.
Dave
Old 11-12-2012, 03:13 PM   #3 (permalink)
bbyer's Avatar
Default Did the clips break or release or both?
Tell us what transpired. Did the existing clips break or release or both?
Also is the rubber strip that jams between the glass and the plastic sitting loose behind the black plastic or is it held in a channel?
I figure on installing a new windscreen and had intended on buying new A post covers and a new cowl piece as well so I wondered what is involved.
2005 LR3 HSE 4.4L V8 petrol; 18" x 10 spoke wheels; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; Air Suspension ECU Fuse 35P disconnect switch; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors.
bbyer is offline   Reply With Quote
Old 11-12-2012, 08:50 PM   #4 (permalink)
member
SafariDave's Avatar
Hi Bruce,
I took the A-Pillar out and found the top peg was broken and the bottom u shape clip holder was 1/2 broken. That it's why the bottom was not flush. Since there was no clip to hold the Pillar against the body channel at the very bottom. Also It had not been replaced with the new clips. The New way is to brake of the bottom peg off the Pillar. Which I broke off with a plier. I covered the bottom and top peg holes on the body channel with the tape's that came with the new clip set to cover the bottom peg hole. Since the top peg was broken (I do not want water coming in through the top peg hole). I put the new clips on the pillar. I was able to put a clip on the 1/2 broken u clip holder at the bottom of the Pillar nice and tight, and I snapped the pillar back. Hopefully it will hold up since there is no top peg. (wondering how much help is the top peg doing). I hope I get no water in through the clips. I can see how water can ingress through the peg holes. I think what happens is that the pegs break, come lose, or since the foam around the pegs are not solid it can let water through.
Dave
How do you remove the Left A pillar on LR3 SafariDave Discovery 3 / LR3 1 10-14-2012 07:33 AM
What are the inner and outer tie rods? Help! Disco811 Discovery 3 / LR3 2 05-25-2012 08:23 PM
Head Gaskets, outer leak - pics discobrian178 Discovery Series II 6 10-21-2009 06:49 PM
Sills Inner and Outer Wing(s)- Fenders the mad hatter Range Rover Classic 3 06-15-2009 06:23 PM
SEO by vBSEO 3.3.2
