» Sponsors
» Sponsors
Old 10-30-2009, 01:18 PM   #1 (permalink)
Default HDC Fault error messages
Every few days I get an error message, reads as follows:
HDC Fault
System not available.
I get 3 warning chimes and 3 warning lights..the brake light and 2 others. I took a picture of the dash when it happened last, but cant figureout how to attach it here.
Anyone ever get this? When this happens, the suspension lowers itself to access level or lower and wont go back to normal unless I turn the truck off and back on
keithd45 is offline   Reply With Quote
Old 10-30-2009, 03:46 PM   #2 (permalink)
Check your battery.It has been documented that weak battery shots out HDC fault first,since it needs a lot juice at start up,.that would be a good start for you.
thorgal is offline   Reply With Quote
Old 11-03-2009, 01:11 PM   #3 (permalink)
Keith, this happened to me the other day. I re-booted it and then drove 600 miles without incident. I hope it doesn't start re-curring. My first guess would be the battery. My battery is new though...so it could be simply a random voltage irregularity. Sensors are constantly monitoring such things.
HOUM_WA is offline   Reply With Quote
need new MAF - P1172, P1175 stolenheron Discovery Series II 21 03-23-2009 12:58 PM
Trouble codes - what should I do? BlackSVT Discovery Series II 7 03-13-2009 11:37 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
