» Sponsors
» Sponsors
Old 10-03-2008, 12:57 PM   #1 (permalink)
Default HELP! (sunroof question)
I just bought (last weekend) a 2005 LR3. Everything appeared to be in proper working order. However, yesterday the sunroof stopped working. It will no longer open. I think it may be something as simple as a fuse, as the vehicle makes no grinding noise ( or any other noise to alert that the sunroof motor may be stuck ). The vehicle did not come with an owners' manual. Could someone please tell me where the fuse box is, and offer any alternatives on fixing it? Has this happened to anyone else?
keanokeanokeano is offline   Reply With Quote
Old 10-03-2008, 05:44 PM   #2 (permalink)
could be a simple stoppage of the motor causes by a loss of battery power. lots of time we just hook up IDS to jump start it by calibrating the motor using IDS and if it works then hey cool. if not then need to diag it.
Old 10-03-2008, 06:28 PM   #3 (permalink)
drzjoint's Avatar
Gallery: 5
there is a fuse box behind your lower glove box
do yourself a favor GET A MANUAL YOU MUST HAVE ONE
this is not a tahoe or h2 I am not a manual guy but you have to get one
check ebay
05 LR3 - 7 SE BLUE V8 aka
THE JUGGERNAUT BITCH"
drzjoint is offline   Reply With Quote
Old 10-05-2008, 03:19 PM   #4 (permalink)
actually you can access your manual by going to landrover.com there is a sight called mylandrover.com there after signing in can you get access to manuals to see how to check a fuse. but the picture of it is on the fuse box though.
Sunroof leak, not the tubes? R_Lefebvre Discovery Series II 5 10-22-2008 01:01 PM
sun roof trim and headlining removal jimllshiftit Discovery Series I 7 09-02-2008 03:23 PM
Anyone converted the RRC sunroof from power to manual? Roverdude Range Rover Classic 1 10-31-2006 02:49 PM
broken front sunroof question aharbour Discovery Series I 5 08-21-2006 10:14 PM
SEO by vBSEO 3.3.2
