Old 11-11-2007, 04:21 PM   #1 (permalink)
Blyzard
LR3dirver4ever's Avatar
Default How to turn on in-bumper fog lamps
How do you go about turning on the fog lamps that come on the LR3 V8 SE or HSE please be some what descriptive thanx
LR3dirver4ever is offline   Reply With Quote
Old 11-11-2007, 10:16 PM   #2 (permalink)
jimbiram's Avatar
When you turn the light switch all the way to the right, it puts it in auto on mode. Unfortunately, in that mode, the fog lights will not go on. Turn the switch left one click, which puts the headlights on. Then, pull on the switch slightly. It will pull out from the dash slightly. ONe click turns on the front fog lights, two clicks will turn on both front and rear fog lights. The rears just add a couple of lights to be seen. The main headlights will remain on in all cases.
jimbiram is offline   Reply With Quote
Old 09-08-2008, 09:54 AM   #3 (permalink)
troverman's Avatar
Our LR3's bumper lights would not turn on even w/ the proper detent engaged. I pulled the lights out of the bumper. Chafing on the driver's side had exposed the wires in both + and - wires, causing them to short out and pop a fuse (#38, 15a, behind glovebox). In fact, the ground wire on the passenger side was exposed too. I taped them all up, replaced the fuse, and voila! Lights again. Our LR3 has the factory installed winch, brush bar, and aux lamps, so not sure if this installation caused the chafing.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
