Mine seems not to work (since I picked the car up), I had the same problem on the Porsche once. I have checked fuse 69 and it seems to be ok. I guess I should have a small light illuminated at the base of the rear view mirror ? There is not a separate on/off switch right ?
Did you try cycling through the menus (press the button on the end of the turn signal/dimmer switch) on the in dash LED? I remember seeing the auto dipping side mirrors controls there, don't know off hand about the auto dimming rear.
'04 Freelander HSE Alveston Red '05 LR3 SE Tonga Green |
I have the same problem with the mirror,,, it doesnt work. When i was in for service i had the service department check the mirror because i was sure it didnt do anything to make my eyes more comfortable at night.
Sure enough, it didnt and a new one is on order. Even the service manager had second thoughts about his demo and sure enough, his didnt work either. So I recommend that you have your service department check it. If they say it works, have them show you how they test it. Best of Luck. |
#4 (permalink) | |
My appointment is on Monday January 16th. As far as the mirror goes, it appears to be powered as the on/off light illuminates and the homelink buttons work properly.
I will let you know how it goes either way. |
Well, appointment went well and had mirror replaced. Sure enough it now works. Its not as dark as other make mirrors, but there is a definite improvement on the glare reduction at night.
