» Featured Product
» Sponsors
» Sponsors
LandRoversOnly.com is the premier Landrover forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 07-28-2010, 07:02 AM   #1 (permalink)
Default lr3 battery
Ive been getting all these different warning messages for some while now, they rang from transmission fault, to parking brake, to HDC not available. These faults only come up while i first crank the truck the instantly go away. Also there's be many times when i have been driving for some time, and i will all of the sudden get a " cruise control not available" message. i was told a while back when this first started happening that it was due to a bad battery, but i have never had any problems with the battery or the car starting, should i just replace the battery anyway?
2005 LR3 HSE
A-Frame guard with PIAA lights
Pirelli ATR's
EX_LR3 is offline   Reply With Quote
Old 08-01-2010, 09:26 PM   #2 (permalink)
If it's the original battery than yes, you should probably replace it. Weak batteries are known for causing similar symptoms.
Geotrash is offline   Reply With Quote
Old 08-10-2010, 11:18 AM   #3 (permalink)
gdlife's Avatar
I have an 05' LR3 as well and just replaced the battery for no other reason then it just died. At any rate before replacing the battery for no reason take it to your local gas station or Auto Zone and have them test it, they will tell you if the battery is preforming up to spec.
gdlife is offline   Reply With Quote
Battery Light on, alternator or battery replacement? Disco Bay Discovery Series II 5 02-23-2010 06:29 AM
Alarm went off all night, battery dead in am, no crank, battery wont engage starter plethra Range Rover P38, Mk III and Range Rover Sport 15 01-22-2010 09:57 AM
95 LWB - dual battery set up - where to install the 2nd battery? ducsurfer Range Rover Classic 3 01-06-2010 05:31 AM
Cold Temp! Battery Light On But New Battery?! vic_rover Range Rover P38, Mk III and Range Rover Sport 1 12-13-2009 05:34 PM
Anyone fit an Optima battery to there LR3 brettmess24 Discovery 3 / LR3 2 11-06-2009 06:46 PM
SEO by vBSEO 3.3.2
