Old 08-12-2008, 08:36 AM   #1 (permalink)
gdlife's Avatar
Default LR3 Suspension fault
I have a 2005 LR3, I am currently getting a suspension fault message and it displays normal height only. Is there a way to check which sensor is causing the issue, if so were are they located? Thank you in advance for your help!
gdlife is offline   Reply With Quote
Old 08-12-2008, 09:56 AM   #2 (permalink)
jmrivera's Avatar
From searching the forum (the search feature is above the thread list on the right-hand side), it sounds like you need to have the system scanned by either the dealer or an independent mechanic with the proper equipment...
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline   Reply With Quote
(S) Trans Sport mode light flashing Disco Xpedition Discovery Series II 15 04-17-2008 06:04 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
Oh man...(flame suit is on) 02disco2 The Lounge 9 03-27-2006 12:51 PM
