LR3 Winch Replacement - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-02-2013, 06:22 AM   #1 (permalink)
Default LR3 Winch Replacement
The spare tire winch on my 2008 LR3 is no longer working after one use (surprise, surprise). I poked my head under there, is it really as easy as taking off those six bolts and it will come loose? Can anyone confirm this who has replaced their winch?
Also, has anyone repaired their winch or should I just get a new one?
Thanks-
MichiganRoverDave is offline   Reply With Quote
Old 01-02-2013, 10:17 AM   #2 (permalink)
bbyer's Avatar
Default Buy a new tyre winch.
Everybody has replaced the spare tyre winch; well it seems that way, and if they have not, they just do not know that it does not work.
I purchased my new genuine one from BP Utah and for once, replacement is a clean hands not too difficult task. The winches are effectively not repairable.
You just need a nice day and a clean surface to lay on under the rear and a metric socket - forget what size but the task is almost pleasant.
The newer winches may be an improved design however once you have the new one installed, do not let the local tyre shop use their impact wrench on it to suck the spare back up. If so, you will at least be more experienced the second time re replacement.
2005 LR3 HSE 4.4L V8 petrol; 18" x 10 spoke wheels; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; Air Suspension ECU Fuse 35P disconnect switch; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors.
bbyer is offline   Reply With Quote
Old 01-04-2013, 12:48 PM   #3 (permalink)
bbyer, thanks for the reply, that's what I figured the answer was, but I thought I would check.
I think I will put a sign under the carpet, on top of the winch that says "HAND TOOLS ONLY NO IMPACT WRENCH" so this doesn't happen again.
looking for LR3 winch bumper mikita Discovery 3 / LR3 7 12-29-2011 02:41 PM
Off-road tyres and winch for 06 LR3? Hugh_Mannity Discovery 3 / LR3 2 05-24-2011 11:05 AM
WTB: LR3 Winch... azaky Land Rover Parts and Vehicles Wanted 1 11-25-2010 12:26 AM
LR3 / Discovery 3 | '05 - '09 Brush Bar Wraparound Non-Winch HeadlinerExpress Land Rover Parts and Accessories 0 03-18-2010 09:53 AM
LR3 with a winch Funrover General Land Rover Discussion 3 11-24-2005 11:22 AM
SEO by vBSEO 3.3.2
