Old 08-11-2008, 11:05 AM   #1 (permalink)
LR3 Guy
Default Nav System Help for 05' LR3
Having trouble setting the system up, just bought my 05' used. When in "on road navigation" menu, only 2 of 4 set up functions are working.
Do I need to reload/by a DVD?
Thanks
mtnkng is offline   Reply With Quote
Old 08-16-2008, 10:59 AM   #2 (permalink)
When the car is in gear, the functions are limited as to what you can do on the screen. It's a safety feature. There is an over-ride "code" to disable this, but you'd have to research it for your LR3 as the "code" is not the same for all years.
If the functions are not working while you're in Park, then maybe your system is fawked.
1hank1 is offline   Reply With Quote
Differential Global Positioning System Expedition Nutter Accessories 3 04-02-2008 04:23 PM
2000 RR Navigation System dbs600 Range Rover P38, Mk III and Range Rover Sport 2 08-06-2006 01:19 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
New Delphi technologies supplied to Land Rover Serg General Land Rover Discussion 3 11-07-2005 12:37 AM
