Need fix for ERROR code p0579-Cruise Control Multi-Function Input "A" Circuit Range/P - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 10-12-2012, 09:37 AM Thread Starter
Quoted: 0 Post(s)
2006 lr3 v-6 68,000 miles
check engine light on
with error code p-0579
ps the cruise control is working!!
Cruise Control Multi-Function Input "A" Circuit Range/Performance
has any one have this problem and if so what was the fix for it
THANK YOU
Joe
rocky1 is offline
post #2 of 6 (permalink) Old 01-02-2013, 03:20 PM
Quoted: 0 Post(s)
I have the same problem. Did you end up replacing the switches in the steering wheel?
dochummer is offline
post #3 of 6 (permalink) Old 06-30-2013, 02:06 AM
Quoted: 0 Post(s)
Thank you for the*informative*posts.
Dostapo is offline
post #4 of 6 (permalink) Old 05-17-2015, 11:36 AM
Quoted: 0 Post(s)
im getting this code as well. did anyone replace the cruise control switches and not get the code?
brjp1 is offline
post #5 of 6 (permalink) Old 05-17-2015, 06:46 PM
tlt
Quoted: 8 Post(s)
Likely one of three, Broken wire (in column head) or clock spring, then switches. Most likely, most expensive Clock Spring, I also need one..
PM me for Diff rebuild Parts, hitches
tlt is offline
post #6 of 6 (permalink) Old 11-23-2016, 05:46 PM
Quoted: 0 Post(s)
THANK YOU
Joe
Were you able to fix this issue and what was the solution? I have the same problem with CEL illuminated and the only code is P0579. Cruise control works well.
Thanks!
Davor
PS. My LR3 is 2006 with 100k and 4.0l V6
davorb is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
"Vehicle fault system shutting down" error Dynamicv1 Range Rover Classic 3 11-27-2013 02:48 PM
04 range hse "air susp inactive" is this a dealer only fix? jawha42 Range Rover P38, Mk III and Range Rover Sport 6 02-20-2012 01:29 AM
Disco "97 AT - ABS and Cruise Control DiscoEric Discovery Series I 2 02-15-2011 04:55 AM
A/C, Cruise Control Issue - Dealer sent me "HOME"! datrix Range Rover P38, Mk III and Range Rover Sport 1 11-23-2010 06:51 PM
1996 D1 Cruise Control not working- any ideas how to fix? Adam in NYC USA Discovery Series I 4 12-21-2007 05:18 AM
You may post new threads
You may post replies
