Old 02-16-2006, 09:17 PM   #1 (permalink)
Default Need uncommon wheel spacers
Hello everyone!!
I was changing original 19" wheels on a LR3 for Range Rover's original 20", pretty cool ones.
I've thought that it would be just OK, cause the nut holes match perfectly.
I've presented them on the vehicle, and they fitted OK, but when I give turns to the wheel, I can see the caliper touches it, just a scratch, but enough to concern about it, so I need to separate the rim. (Front wheels only).
The questioned part of the rim, has an angle that only changes after you separate the wheel about 5mm, I've already measured it.
Anyway, I've bought and installed 6mm good quality wheel spacers and made a test driving.
Around 80km/h, it starts shaking, BIG TIME!!
Back to the shop, I take the wheel out, think a little bit, and I figure out what happened:
The center of the rotor has this 6mm thick section, that fits to the rim very firmly, and centers it, preventing unconvenient "radial shaking".
After analyzing the nuts, that have not cone shapped ends, I can see that the correct fitting of the wheels, depends on this little section, so when I add the spacer, the wheel got unlocked, and uncentered, so it shakes like hell.
Is there a product that could solve this problem? I just need a 5mm separation.
Don't want to grind the caliper for ovious safety reasons.
Don't want to grind the rims cause they're still owned by someone else.
Thanx for any help.
Good luck.
Kaliman is offline   Reply With Quote
Old 02-18-2006, 03:57 PM   #2 (permalink)
LR3 and RR use two different style hub and bearing setup. Thats why it rubs.
They wont work, You might be able to do one for the RRS but I doubt that. If I remember they use the same hub.
Also too you need original lugnuts to make it work. thats right all twenty lugnuts.
Old 02-18-2006, 04:26 PM   #3 (permalink)
Otherwise known as STEVE
You could have a hubcentric adapter made- it'll take a decent machine shop and some time... then put on the correct nuts too.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 02-19-2006, 01:06 PM   #4 (permalink)
The new 20" rims comes from RRS.
I've already ordered special made adaptors, there's enough space in the center of the hub to attach a hub extention, using the axel's nut, already designed it with the engineer, will use stainless steel.
Wish me luck.
Thanx 4 the help, your replies have been very useful.
Old 02-24-2006, 10:48 PM   #5 (permalink)
Hello again!!
I got specialmade stainless steel hub extentions and AL spacers. Everything was seem to be nice, we where very careful with design, measurement, and machining. $$$
But it didn't worked
It still shaking a little bit at 120kph.
I'll see if I can improve something else.
Already remeasured, balanced wheels, cleaned surfaces, checked for loosen parts. It just keeps shaking.
I'll try to shot some pics' in order to show you, so you can reply about it.
See you.
Old 02-25-2006, 04:19 PM   #6 (permalink)
If it keeps shaking then dont put them on.
its obvious your spacers were either designed wrong or not even right.
I think if I were you I would stick with the original. IT will give you alot less problems.
Old 02-25-2006, 11:43 PM   #7 (permalink)
20" belong on no Land Rover, espacially on a Disco. If you want 20" wheels get a Cayenne, not a LR.
Ferrarislave is offline   Reply With Quote
