Old 07-18-2008, 07:28 PM   #1 (permalink)
Default Off Road Lights
I've put on 4 hella 4000's on my roof rack. I am usuing two relays into one dash mounted switch. I own a 2006 LR3 and need a little bit of help.
I am having issues where to tap my power source into for the switch.
I have been told I just can't splice/tap into any old wire on my LR3 since the LR3 has a special computer system in which if I mess with might screw something up.
I know most people just tap into the parking lights or the fogs and even the main head lights.
I also know Land Rover sells a factory light set. How are those lights wirred into the LR3.
I would love any help out there.
Thanks,
Hiserote
hiserote is offline   Reply With Quote
Old 07-18-2008, 08:19 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
if your looking for a constant 12v source you could always tap straight off the battery. A ring connector some wire a fuse inline for safety sake and your on your way.
I don't know the LR3 electrical system well enough to tell you where to safely tap in. I would try tappin in at the factory fog light switch though if it was my truck.
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 07-23-2008, 04:35 AM   #3 (permalink)
Tripping the light fantastic...
Christopher Winslow's Avatar
Yes be careful most systems in the truck are monitored. However you can tap power from the 12v ACC lines in the dash for your electronics. Those should give you power to run the switch, I would also put a fuse inline there as well, so you don't blow your line.
Winslow
The Doctor: I don't suppose you've completely ignored my instructions and secretly prepared any Nitro-9, have you?
Ace: What if I had?
The Doctor: And naturally, you wouldn't do anything so insanely dangerous as to carry it around with you, would you?
Ace: Of course not. I'm a good girl and do what I'm told.
The Doctor: Excellent. Blow up that vehicle.
7th Doctor and Ace, "Silver Nemesis"
1996 LR Discovery SD - Victoria
2005 LR LR3 SE V8 - Oliver
Christopher Winslow is offline   Reply With Quote
LR3 Off road lights wormsvho Land Rover Parts and Accessories 0 08-09-2006 05:51 PM
Driving Lights or Fog Lights? 2002DiscoII Accessories 4 01-24-2006 04:48 PM
Hella 500 lights BIRD Discovery Series II 9 08-24-2005 05:31 PM
Looking for Off Road Lights with Harness and Wiring Assembly curedude Accessories 2 05-13-2005 02:26 PM
How to hook up auxiliary lights? BIRD Discovery Series II 3 03-15-2005 10:04 AM
