pulls to the right - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 01-07-2011, 02:37 PM Thread Starter
Quoted: 0 Post(s)
pulls to the right
My LR3 05 when I travel at low or high speeds.I have new tires and have had a front end alignment and new both lower control arm replaced. So what could be wrong?
dragan is offline
post #2 of 7 (permalink) Old 01-07-2011, 10:02 PM
Quoted: 0 Post(s)
Let's break it down...
In what order did you have this stuff done? What tires are your running? How new is new? Who did the alignment? Have you checked your tire pressure?
The factory issue Goodyear Wranglers are garbage. If that's what you're running I'd check them for cupping.
Dave Legacy is offline
post #3 of 7 (permalink) Old 01-08-2011, 04:31 AM Thread Starter
Quoted: 0 Post(s)
Ok
4 michelin latitude tire installed on 10-11-10 55.765 k mile,both front control arm and alignment on 4-1-11 57.938 k mile. All work has ben completed by LR shop.
Thanks
dragan is offline
post #4 of 7 (permalink) Old 01-08-2011, 10:38 AM
Administrator
Quoted: 5 Post(s)
What air pressure????????????????????????
Have you bounced off a curb recently?
I would go back to whoever did the alignment, although most shops won't put a time/mileage warranty on alignments, but that is where you should start looking.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #5 of 7 (permalink) Old 01-08-2011, 11:58 AM Thread Starter
Quoted: 0 Post(s)
I told before to the LR shop about the vehicle pulls to the right.
Answer from the LR:
TEST DROVE AND NOTED VEHICLE DRIFTING WHIT THE CROWN OF THE ROAD.
VEHICLE TRACKING AND BRAKING WITHIN SPECT.
dragan is offline
post #6 of 7 (permalink) Old 01-08-2011, 04:10 PM
Quoted: 0 Post(s)
Tracking with crown of the road is probably all that's happening. Look at the roads and decide if it's pulling more than it should, but even a perfect alignment will follow ruts and stuff. If you're compensating to keep it driving straight then it might be a true alignment issue.
post #7 of 7 (permalink) Old 01-08-2011, 04:13 PM
Quoted: 0 Post(s)
An accurate air pressure reading is necessary to figure this out. We have your answer if your right front corner is much lower than the left.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Rover pulls 2 Toyotas at once!!! Funrover General Land Rover Discussion 5 11-29-2007 09:24 AM
UNO Truck Pulls RageRover Off Road 38 09-03-2006 03:08 PM
RR pulls to the left when braking ..... HaroldC Range Rover Classic 4 05-29-2006 04:09 PM
trailers.....who pulls Funrover General Land Rover Discussion 8 04-12-2006 10:07 AM
Steering pulls Kevin88RRC Range Rover Classic 19 04-08-2005 10:59 AM
You may post new threads
You may post replies
