My steering wheel seemed to “loose” and had little control when in deep sand
( wheels were going straight while steering wheel was upside down) My setup at the time -sand program (tried mud) - Low range - Off road height Occasionally I got a graphic on my instrument panel (I do not have NAV) which shows my wheels and axle |
Sounds like you were moving too fast. If you wouldn't have turned your wheels, you would have probably gotten stuck. That's a normal reaction in sand or mud. Its a good thing too unless you REALLY need to turn in which case you can use both feet, one to brake a bit and one to keep the engine accelerated while in gear.
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD 2.25L Dsl - Wilks 1965 Series IIa 88' LHD 2.25L Petrol - Fionna |
Ben
same thing happens to me in deep mud. You still running the stock tires? when i switched to MT's I gained a less loose feeling, but it's still their
1997 D-90 #1345- back to stock 2002 Dodge ram 2500CTD- dd/tow rig looking to do 1 ton toyota or rover |
I am still running stock tires . I never lost control it just seemed that the steering ratio may have changed . i put my head out the window and my tires were straight a head ,however my steering wheel was upside down.
yep! all went back to normal, I am also thinking it may have somthing to do with anti-roll mitigation ( if there is cetian amount of resistance to the tires and the direction of steering in an effort prevent over corection ) Does that make any sence?
#8 (permalink) | |
Ben
