Old 07-07-2006, 07:18 AM   #1 (permalink)
Default steering issues 06 lr3
My steering wheel seemed to “loose” and had little control when in deep sand
( wheels were going straight while steering wheel was upside down)
My setup at the time
-sand program (tried mud)
- Low range
- Off road height
Occasionally I got a graphic on my instrument panel (I do not have NAV) which shows my wheels and axle
nwcarter3 is offline   Reply With Quote
Old 07-07-2006, 08:14 AM   #2 (permalink)
01001010's Avatar
Gallery: 15
Sounds like you were moving too fast. If you wouldn't have turned your wheels, you would have probably gotten stuck. That's a normal reaction in sand or mud. Its a good thing too unless you REALLY need to turn in which case you can use both feet, one to brake a bit and one to keep the engine accelerated while in gear.
JC...
Old 07-07-2006, 01:00 PM   #3 (permalink)
Ben
TN-LR3's Avatar
same thing happens to me in deep mud. You still running the stock tires? when i switched to MT's I gained a less loose feeling, but it's still their
1997 D-90 #1345- back to stock
2002 Dodge ram 2500CTD- dd/tow rig
looking to do 1 ton toyota or rover
TN-LR3 is offline   Reply With Quote
Old 07-07-2006, 01:45 PM   #4 (permalink)
smileyq's Avatar
Hey Ben you get a RRC yet?
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
Old 07-07-2006, 02:49 PM   #5 (permalink)
I am still running stock tires . I never lost control it just seemed that the steering ratio may have changed . i put my head out the window and my tires were straight a head ,however my steering wheel was upside down.
Old 07-08-2006, 12:15 AM   #6 (permalink)
smileyq's Avatar
Thats crazy man. Obviously everything went back to normal when you got out of the mud/sand right?
Old 07-08-2006, 10:29 AM   #7 (permalink)
yep! all went back to normal, I am also thinking it may have somthing to do with anti-roll mitigation ( if there is cetian amount of resistance to the tires and the direction of steering in an effort prevent over corection ) Does that make any sence?
Old 07-09-2006, 03:13 PM   #8 (permalink)
Ben
TN-LR3's Avatar
naa man my dad thinks it will cost a grand a month to keep the thing running which isn't true. So i'm just not going to wheel the LR3 too much anymore and hopefully buy some skidplates later on this summer when i get a couple of paychecks from work.
