Old 05-26-2008, 12:02 PM   #1 (permalink)
Default Tailgate problem
I have recently purchased an 05 disco 3 which to date has been without fault. Today however I loaded some bins in the back and needed to apply a small amount of pressure to get the upper tailgate section to close as one of the bins was too far back. The tailgate closed OK but I am now unable to open it. The manual I have suggests that I press both buttons on the remote together for 3 seconds but this dosn't seem to achieve much apart from flashing indicators and the locking mechanism operating. When I press the handle of the tailgate it makes the right noises but it dosn't release. Any suggestions please ?
MAMBOOSAL is offline   Reply With Quote
Old 05-27-2008, 10:41 AM   #2 (permalink)
Sounds like the end of the cable has broken off, if this is the case you will need to order a new latch.
partsguy is offline   Reply With Quote
Old 06-03-2008, 05:35 AM   #3 (permalink)
Thanks Partsguy. You got it spot on according to the dealer.
The only worry I have is that the dealer seemed to know what the problem was as if he has seen it a number of times !
Wierd Range Rover Classic Problem NikeCheck246 Range Rover Classic 5 03-06-2008 11:56 AM
tailgate lock problem on 95 Disco catseye Discovery Series I 4 09-26-2006 12:21 PM
rr v8 4.4 nikasil problem???? please help. 2002hse General Land Rover Discussion 4 10-19-2005 02:00 PM
rr v8 4.4 nikasil problem???? please help. 2002hse Range Rover P38, Mk III and Range Rover Sport 2 10-12-2005 09:11 AM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 08:52 AM
