Towing with a LR3 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 11 (permalink) Old 07-16-2012, 05:41 AM Thread Starter
Quoted: 0 Post(s)
Towing with a LR3
I am looking to get an LR3 but I need to know 2 things before I can commit to one. First, do the LR3's come standard with a receiver so I can tow my 21 foot boat? And second, does anyone know the towing capacity? I have read its about 6000ibs. Thanks
jbstephenson is offline
post #2 of 11 (permalink) Old 07-16-2012, 07:51 AM
bbyer's Avatar
Quoted: 1 Post(s)
21 ft boat or yacht?
If it is a 21 ft fly fishing runabout, then no problem; if it is a 21 ft inboard outboard with a galley and flying bridge like the one the Chev 2500 tows on that TV ad, well that will be a problem.
Below is a link to some hitch related files I have compiled.
DISCO3.CO.UK Photo Gallery - NAS Trailer Socket Pin ID and Wire Colours
Your 3 may already have tow wiring installed but the wiring was not standard equipment. The proper wiring setup matters as the factory wiring allows the 3 to sense that a trailer is connected and invokes limitations on air suspension movement and other things.
As to the hitch, Curt makes a bolt on variety and Land Rover has a lock in to a slot type. If you are buying one of these, purchase the newer shorter LR4 variety.
2005 LR3 HSE 4.4L V8 petrol; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors; LR4 hitch receiver; Wiggs D4 Bluetooth Module; 3 Blink signal light feature; Clock on the Dash; D4 Backup Camera; 2015/16 Nav Data update.
bbyer is offline
post #3 of 11 (permalink) Old 07-17-2012, 05:57 PM
tlt
Quoted: 9 Post(s)
You never cease to amaze me with your wealth of useful information and help. I can't wait until you come this way, or me yours so I can meet you.
PM me for diff Parts, hitches, snomaster fridges
tlt is offline
post #4 of 11 (permalink) Old 07-24-2012, 04:13 PM
Quoted: 0 Post(s)
The receiver is not OEM standard. It is aftermarket purchase and list is around $500, but you can find them on eBay for $350 and up.
Wiring harness from Atlantic British is $129 and is a DIY project if you have the time, beer and patience to get the plug into the space, and can thread the harness properly.
A 21' boat of any kind will be easily towable with an LR3, and will actually increase in value when linked to your truck.
Rick
lower Alabama
2007 LR3
bamaboy473 is offline
post #5 of 11 (permalink) Old 07-25-2012, 10:59 AM
lwg
lwg's Avatar
Quoted: 0 Post(s)
The LR3 tows great. The only real limitation is the wheelbase, otherwise it's got plenty of power and brakes. The max towing capacity is 7700 lbs, but you'll likely want to stay south of that a bit as that starts to get very heavy. The real limitation is that you only have about 1,000 lbs to play with in regards to people, luggage, etc AND hitch weight. This to me is the biggest limiting factor.
I went with the Curt bolt on hitch as I just don't trust the OEM one. But that's just my opinion.
lwg is offline
post #6 of 11 (permalink) Old 07-25-2012, 11:25 AM
Quoted: 0 Post(s)
I never understood why someone would get the Curt unit when the factory LR unit is integrated into the truck, etc. Everytime I see the Curt unit I just laugh...really?
So, original poster...do yourself a favor and just get the factory receiver and factory lighting setup. It's the way to go. No need to hack it.
bjwhite is offline
post #7 of 11 (permalink) Old 07-25-2012, 02:53 PM
bbyer's Avatar
Quoted: 1 Post(s)
probably the newer shorter one is better
Below is a link to re what was mostly likely an isolated problem with the older longer style plough hitch on a D3 in Australia.
Broken Disco 3 Tow Bar - Australian Land Rover Owners
The general feeling was that the hitch was most likely used as a recovery point rather than solely as a towing point; also trailer safety chains have some merit as all ended well.
The sort of brown coloured jpg is from a Prado demonstrating a similar concern. I suspect I could find a Curt looking about the same.
Name:	D3 hitch broken IMG_0208.jpg
ID:	31835   Click image for larger version
Name:	Prado broken tow receiver.jpg
bbyer is offline
post #8 of 11 (permalink) Old 07-25-2012, 03:55 PM
lwg
lwg's Avatar
Quoted: 0 Post(s)
The Curt hitch doesn't hang as low as the factory hitch. And to be honest provides a little protection when offroading as I have the full size spare.
I regularly use my bike rack on my LR3 which mounts to the hitch.
lwg is offline
post #9 of 11 (permalink) Old 07-26-2012, 04:12 PM
tlt
Quoted: 9 Post(s)
Isn't the nickname for the LR OE hitch "the plow" that should explain among other reasons why folks look for an alternative. Just because you don't agree is not a reason to start a bash session, you can use what you choose. Given the choice and budget, it would be Mitch Hitch or like it for me.
tlt is offline
post #10 of 11 (permalink) Old 12-11-2012, 01:42 PM
Quoted: 0 Post(s)
I have an LR3 05 SE with Factory hitch and I'm able to tow 24 ft camper ~ 5000lbs with no problems, put it in low gear when driving slow ie. backing up. I bought the car just for this feature and I can load the car up with 7 people.
Mike B is offline
post #11 of 11 (permalink) Old 12-11-2012, 06:16 PM
Quoted: 0 Post(s)
Ive towed my D2 with my D3 thousands of miles with no problem.
2006 D3 - Lifted w/ 33's, T/R Front Bumper
2000 D2 - Trail Truck
1999 P38 - California Girl
716-898-8153 M-F 9am-5pm
WNYDisco3Erik is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Better Towing NYChaze Discovery Series II 6 05-02-2011 01:59 PM
Towing? beecoach Discovery Series II 7 03-09-2009 10:08 PM
LR3 Towing Specs TrentE Discovery 3 / LR3 2 07-28-2008 04:49 AM
Should I be towing a..... LANDY96 Discovery Series I 5 01-06-2006 03:19 PM
towing PD2179 Discovery Series I 7 09-24-2005 11:49 PM
You may post new threads
You may post replies
