Will 19" rims from an '03 Range Rover fit an '08 LR3? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 14 (permalink) Old 10-08-2011, 08:47 AM Thread Starter
Quoted: 0 Post(s)
All:
Here's the rim;
Came from a 2003 Range Rover MkIII/L322/Full size. I have seen ads where it says they will fit but need to know for sure before I commit to a 5 hour drive to get them!
If anyone can confirm, I'd really appreciate it. .
Paul.
'08 Land Rover LR3
'86 Ninety V8 Station wagon
'89 Classic Mini
Gone but not forgotten:
'07 Range Rover HSE, '89 Targa, '96 Land Rover Discovery SD, '00 Range Rover HSE, '07 FJ Cruiser, '04 Land Rover Discovery SE7, '96 Porsche 911 Carrera 4 Coupe,'04 Mini Cooper S, '11 Mini Cooper Countryman All4, '83 Porsche 911
Paul K is offline
post #2 of 14 (permalink) Old 10-08-2011, 11:02 PM
Quoted: 0 Post(s)
I am running 19" RR wheels (2006 I believe and they appear different than your picture) on my LR3 HSE without issue. They have 4mm or so less offset but you can't tell and the vehicle drives fine.
That being said the wheels you mention will fit but the lug nuts will not.
You MUST use the correct lugs or big trouble. Land Rover changed from a square lug to a tapered cone .
Happy reading.
Compatibility Between Model Years and with LR3/Disco3/RR Sport Wheels:
Officially, 2003-05 Range Rover wheels are incompatible with later models and vice versa, and all RR III wheels are incompatible with LR3 and RR Sport wheels. RR III wheels have a 57 mm offset, whereas 53 mm is used on the LR3 and RR Sport. Also, the earlier Range Rover lug nuts had square ends and the D3/LR3/Sport ones have tapered ends (see photo at right). In 2006, Range Rover wheels were redesigned to accept the RR Sport and LR3 lug nuts. However the 57 mm offset was retained.
Photo at right adapted from TSB # LM-204-001 (July 2005) on wheel compatibility.
So, officially you are not supposed to mix early and late wheels, or use wheels from the inferior models.Unofficially, the later RR III wheels are fine on the earlier models if you buy the later lug nuts (about $400 for a complete set from the dealer, or less than half that from the Rover Connection). I know at least one 2003 RR owner who uses 2006 wheels with the old lug nuts and has reported no problems, but do so at your own risk!! Similarly, it is probably feasible to use DiscoIII/LR3/Sport wheels on the Range Rover (with the appropriate lug nuts), but the slightly different wheel offset may adversely affect steering and wheel bearing wear. If the 17 inch D3 wheels will fit (which I doubt, see above), they would be useful for short term use such as extreme off road expeditions, due to the much larger range of aggressive tires available for them.
If you have any other info on this topic, please email me).
Mk III Range Rover Tire Choices
ktm_525 is offline
post #3 of 14 (permalink) Old 10-09-2011, 08:10 AM Thread Starter
Quoted: 0 Post(s)
Thanks!
'08 Land Rover LR3
'89 Classic Mini
Paul K is offline
post #4 of 14 (permalink) Old 10-09-2011, 08:16 AM
Quoted: 0 Post(s)
Click the link at the bottom of my first post. That will take you to the page wherer I cribbed the info from. Very informative with lots of wheel pics.
ktm_525 is offline
post #5 of 14 (permalink) Old 10-16-2011, 10:59 AM Thread Starter
Quoted: 0 Post(s)
Great news! So the inevitable next question- cheapest source of the older style lug nuts?
'08 Land Rover LR3
'89 Classic Mini
Paul K is offline
post #6 of 14 (permalink) Old 10-17-2011, 08:22 AM
Quoted: 0 Post(s)
perhaps BP of Utah or Atlantic British. I think a LR set will run $200. I would look for 06+ 19" RR wheels off of Ebay. A steady floww of 19" RR wheels out of Cali. The wheels look better too. How is the rubber on the set you are looking at?
ktm_525 is offline
post #7 of 14 (permalink) Old 11-05-2011, 02:35 PM Thread Starter
Quoted: 0 Post(s)
All:
Needed the different lug nuts and spacers on the fronts.
Here they are on my Father in law's '06;
I think they look great!
Thanks,
Paul.
'08 Land Rover LR3
'89 Classic Mini
Paul K is offline
post #8 of 14 (permalink) Old 11-08-2011, 08:01 AM
Quoted: 0 Post(s)
All:
Thanks,
Paul.
They do look good. I am surprised you needed a spacer on the front. Wheels contacting the caliper?
ktm_525 is offline
post #9 of 14 (permalink) Old 11-09-2011, 08:46 AM
bbyer's Avatar
Quoted: 0 Post(s)
Positive offset greater so maybe 4 mm matters.
The bigger the positive offset number, the more the wheel wraps around the brakes etc. Maybe 4 mm does matter, 53 mm v 57 mm.
There is also the question of wheel weight rating and if it matters.
The wheels of a 3 are rated at 940 kg; the RRSport, 900 kg, and the FFRR, in between at 925 kg. Does it matter? I presume Land Rover thinks so.
2005 LR3 HSE 4.4L V8 petrol; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors; LR4 hitch receiver; Wiggs D4 Bluetooth Module; 3 Blink signal light feature; Clock on the Dash; D4 Backup Camera; 2015/16 Nav Data update.
bbyer is offline
post #10 of 14 (permalink) Old 11-12-2011, 05:47 PM Thread Starter
Quoted: 0 Post(s)
Yes. I added 3mm spacers and all was good.
I see this style of rim for sale cheap all the time- pity I had to put $200 into lug nuts & spacers!
'08 Land Rover LR3
'89 Classic Mini
Paul K is offline
post #11 of 14 (permalink) Old 11-17-2011, 08:59 AM
Quoted: 0 Post(s)
They look good though. The king of cheap 19" wheels would have to be the latter Range Rover models. I know the 06 Range Rover 19" fit the LR3 without spacers or new lugs. They kick the tires in 3-4mm which is not noticeable.
The 19" wheel and the 255/55 size is quickly becoming the red-haired stepchild of the tire world though. Selection of quality winter tires in this size is disturbingly limited. Right now Pirelli Ice&Snow but even those are problematic in terms of supply.
ktm_525 is offline
post #12 of 14 (permalink) Old 11-17-2011, 03:06 PM
bbyer's Avatar
Quoted: 0 Post(s)
You really want 18" but they are not cheap.
18" factory D3 rims with a 940KG rating is what you really want I would say. The problem is that everyone else wants them as well and that is why 19" are for sale everywhere and the 18" are hard to find.
The LR part number of the 10 spoke x 18" x 8" is as below is ALY72190U. These have the 940KG required rating. The FFRR wheels are generally less.
Name:	LR3 Sparkle Silver 10 spoke Wheel Cromodora of Italy 18 inch x 8  ALY72190U.jpg
ID:	29962   Click image for larger version
Name:	LR3 with 18 inch wheels.jpg
bbyer is offline
post #13 of 14 (permalink) Old 10-09-2014, 01:30 PM
Returning Rover
Rovingvic's Avatar
Quoted: 3 Post(s)
Why are people interested in the 19 inch rims? Tire selection for 19 inch rims is terrible. I have found only 1 A/T tire: Goodyear Wrangler DuraTrac 255/55-19 XL that fits a 19 inch rim size.
You shouldn't have to stop just because the pavement does!
2012 Evoque Pure Plus Coupe
2009 LR2 HSE - traded
2008 LR2 SE - traded
Rovingvic is offline
post #14 of 14 (permalink) Old 10-10-2014, 09:28 PM
Quoted: 0 Post(s)
well the truth is I just bought my lr3 and it came with these flashy 22 or 23 inch wheels. I purchased the vehicle to get through bad weather this winter when commuting to and from school and my children's home up north. I searched on EBay and amazon for some time for 18 in. wheels at a decent price until I came across these 19 in wheels with relatively new (9/32 tread) Bridgestone duelers for less than the price of the wheels through other sellers. Couldn't pass it up and had to get these matchbox wheels off my truck. so yeah I would love to sit on more meat but after spending thousands on parts accessories and labor to get it winter ready my wallet needed a break. So if at all possible could you or ktm_525 instruct me on exactly what I need to make these wheels compatible with my lr3? It would be greatly appreciated.
n8
n8than808 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
(4) 16" Typhoon Rims - D2 and Range Rover Bozman Land Rover Parts and Accessories 0 06-13-2011 06:12 AM
19" land rover rims fit 98' Disco 1? hdalley09 Discovery Series I 3 06-02-2009 10:21 AM
Rims that fit LR3 drzjoint Discovery 3 / LR3 0 02-24-2009 09:14 AM
Can 15" rims fit a 99 Disco? 98xc800 Discovery Series II 11 04-21-2008 08:44 AM
You may post new threads
You may post replies
