ZF 6HP26 Automatic Transmission Metal Pan with Filter - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 02-16-2012, 09:36 AM Thread Starter
Quoted: 0 Post(s)
I have about 70K miles on my LR3 SE and after reading all the posts regarding the transmission, I have decided to do a fluid change. However, would anyone know a ZF indy shop in Southern California preferably in Orange County? I would like to change to Metal Pan and filter if DIY or if it's done by a shop.
I have seen a video on youtube for a pan change out on a jaguar which has the same transmission layout and it seemed not a major task as long as the necessary tools are available. If I've read the post correctly at some point one needs to lift the transmission/engine? to get access to the fill plug. Is that a major task?
Your thoughts are greatly appreciated and thanks in advanced!
2005 LR3 SE V8 4.4L
bodyzoo is offline
post #2 of 10 (permalink) Old 02-16-2012, 02:21 PM
Super Trooper
cnfowler's Avatar
Quoted: 13 Post(s)
Garage
The right side of the engine does need to be lifted 1.38 inches according the the workshop manual. This is in order for the tranny pan to clear the crossmember to be removed.
Colin
cnfowler is offline
post #3 of 10 (permalink) Old 02-17-2012, 11:03 PM
bbyer's Avatar
Quoted: 1 Post(s)
Lifting engine only necessary to remove pan/filter combo.
If one was just replacing the tranny oil, it would not be necessary to lift the engine. The engine lift requirement results from a desire to remove the plastic pan/filter combo. The filter portion includes a vertical plastic pipe that feeds oil back up into the tranny. The vertical length of the pipe precludes sliding the pan out without the engine lift.
In Australia, where the guys are installing a metal pan for the first time, they "saw" off the plastic pipe during the dropping procedure and then remove the pipe separately after the plastic pan has been removed.
Then a new separate ZF oil filter is installed and the new ZF metal pan is slid in without the necessity of the engine lift.
DISCO3.CO.UK Photo Gallery - ZF 6HP26 Automatic Transmission in LR3
2005 LR3 HSE 4.4L V8 petrol; Traxide dual battery kit; Rear Cargo area LED lighting; PIAA 2500K H11 Yellow Ion fog light bulbs; Patch cellular antenna to underside of interior of glass roof; CounterAct LT-2 capacitive corrosion control system; LLumar AIR80 Blue Low E clear Infra Red heat reducing side window tint; Manual upper rear door cable release; Schrader valve "air in" mod to OEM air tank; Akebono ceramic pads on OEM solid vented rotors; LR4 hitch receiver; Wiggs D4 Bluetooth Module; 3 Blink signal light feature; Clock on the Dash; D4 Backup Camera; 2015/16 Nav Data update.
bbyer is offline
post #4 of 10 (permalink) Old 02-18-2012, 09:47 AM
tlt
Quoted: 9 Post(s)
I send the suggestion for installation by bbyer and cnfowler. That is how I fitted mine, there is no need for lifting.
I am working on sourcing the pan at significantly reduced pricing.
PM me for diff Parts, hitches, snomaster fridges
tlt is offline
post #5 of 10 (permalink) Old 02-18-2012, 10:11 AM
Super Trooper
cnfowler's Avatar
Quoted: 13 Post(s)
Garage
Originally Posted by tlt View Post
...I am working on sourcing the pan at significantly reduced pricing.
I am interested to know what you find out. I've done quite a bit of searching for the metal pan, but haven't had a bunch of luck. I found one on eBay's UK site, but that's it. I've used the ZF part number and still no luck searching Google.
Colin
cnfowler is offline
post #6 of 10 (permalink) Old 02-18-2012, 01:04 PM
Former LR tech, Albany NY
Quoted: 0 Post(s)
We just do the bg transmission flush, does all the fluid, not just whats in the pan and its cheaper and lasts longer. plus you dont have to pull the pan, just pull one hose off the radiator and hook up the machine, then run the vehicle and all the fluid is changed. any other way is a waste of time.
I used to work on Rovers. Got a question just ask, need a Rover looked at, Albany, New York.
Rovin4life is offline
post #7 of 10 (permalink) Old 02-18-2012, 02:24 PM
Super Trooper
cnfowler's Avatar
Quoted: 13 Post(s)
Garage
What about changing the filter? What are your opinions on that?
Colin
cnfowler is offline
post #8 of 10 (permalink) Old 02-19-2012, 06:41 PM
bbyer's Avatar
Quoted: 1 Post(s)
The filter - does it matter?
I am one of those guys who thinks that doing an engine oil change and not installing a new oil filter just shortcuts the purpose of the process. I see the goal as removing contaminants from the engine rather than from the oil and then storing them in a filter. In the case of an engine oil filter, a filter change is cheap and easy.
This whole business of flushing trannies I just do not understand. It lends itself very well to near fool proof tranny oil changes but it is not clear to me that the goal is achieved - that is removal of contaminants from the tranny.
If you believe ZF, the 6HP26X is supposed to have some sort of exotic oil poured back in. While the formulation is secret, I gather it must contain stardust as it it priced that way. Regardless, it is not clear to me that all the oil you end up with in the flushing process is the stardust oil and not oil from the previous tranny that was flushed.
Also removal of the pan allows one to look at the two magnets and see what is sticking to them. The consistency of the paste or size of the chunks that adhere to the magnets gives you a clue to what is going on with the hard parts.
Also the oil you drain out you can look at and you know where it came from. The colour, taste, feel and smell of what comes out tells a story.
Once you have gone to the effort of pulling the pan, a new filter is of course a given. That is why the metal pan option has great value. It makes pulling the pan more Chevrolet like and less German.
bbyer is offline
post #9 of 10 (permalink) Old 02-20-2012, 06:38 AM
Quoted: 0 Post(s)
your way only changes some of the fluid. at the same time the new fluid mixes with the old and doesn't do as good as a job. The entire fluid fluid flush bypasses the filter especially since they don't need changing. Don't believe me, the original disco twos only needed the filter changed once at 30k after that you didn't need it till 150k. These newer trannies don't need a fluid flush till 150 but its wiser to do earlier. Plus its easier on your wallet and your time to do the flush. Its a hour out of your time at any place that services them. not just a dealer. Don't believe me check out bgfindashop.com in your area. You will be surprised the fluid they use in the big box works for newer transmissions and is cheaper then LR fluid.
plus you have to jack the transfer case up to remove the cover and then you have to fill up the side in a very small hole. not easy especially on your back.
post #10 of 10 (permalink) Old 02-26-2012, 07:14 PM
Quoted: 0 Post(s)
Parts you need for the metal pan conversion
> Item ZF part#
> Steel pan 1068 203 042
> Gasket 1068 303 017
> Filter 0501 213 359
> Pan screws 0736 010 347 requires 21 screws
You can contact Erikson Industries in Saybrook CT, 800-388-4418 to have the parts order from Germany for you...
samnt650 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
97 D1 Automatic Transmission 115k....400obo roverdisco1017 Land Rover Parts and Accessories 2 11-13-2011 11:42 AM
Pulling the transmission sump pan N2RRClassic Range Rover Classic 3 07-29-2011 07:16 AM
Piece of metal found in oil pan johnsoax Discovery Series I 8 12-09-2010 11:46 AM
Transmission Pan search from Busted DS... sounder Discovery Series II 6 07-20-2009 04:06 PM
Changing automatic transmission oil - help imag Discovery Series II 0 10-02-2005 01:27 PM
You may post new threads
You may post replies
