Old 06-16-2008, 08:23 AM   #1 (permalink)
got mud?
Jupiter Rover's Avatar
Default 235/85 or 285/75 for mud/trail? skinny 32" or wide 33"
I have to order new tires this week. So, after researching many different types of mud terrains, I have decided to go with Firestone's Destination M/Ts. The reviews say they wear great on road ( this is a must since my rover is a DD, however I do hit the trails nearly every weekend). Reviews and members of the forum also have stated that they perform better in mud then the BFG.
I currently run a 285/60/18 nitto grappler.. and I have wanted a pizza cutter for some time (ideally a 255/85. Firestone does not make this size)
Since the mud gets so deep here in south Florida I like the height of the 285/75.. I have 779/762 OME springs and have already searched, people said 285s fit. I do barely any flexing so rubbing isn't an issue. What I want to know is what would be better for mud and trail.
235/85: skinny, supposedly better in mud because of its narrow width, BUT 32"
285/75: tall, added clearance could help me get through more of Florida's swampy terrain.
Would the skinny but shorter tire be a good compromise for a much wider, One inch taller tire.
or would the added height of the 285 be more beneficial.
I read about Every thread that included "235/85", "285/75" and "255/85." Maybe I should flip a coin haha..
thanks in advance.
p.s. This is on dweb as well, I was not sure if all you guys here check dweb.
Here are some pictures of the 285/75, compliments of Expedition Roverland.
Support & Sponsors
DII
-- Pete
Old 06-16-2008, 12:14 PM   #2 (permalink)
brooksa's Avatar
Are you still running 18's?
2004 DII SE7
brooksa is offline   Reply With Quote
Old 06-16-2008, 03:16 PM   #3 (permalink)
Thor's Avatar
I've never run the 255/85 BFG M/T but some friends have. The ones that did not like them thought they were tippy way off camber and they have gone to and love the 285/75. They are both Colorado guys. A guy in Chicago where they play in fields of mud prefers the 255/85 because of less resistance to forward progress in the width. Could he really tell 30mm less width?? He always replied yes when it's times 4 tires. Who knows.
Rumors and hearsay is all I can provide.
I used to be a narrow freak, but by the time I made the mental jump to run 35's, 12.5 was the only width 35" cam in a non specialty tire (i.e. Simex & Interco)
Todd
Carpe Rangius Roverum
Old 06-16-2008, 03:52 PM   #4 (permalink)
thanks in advance.
Support & Sponsors
Your spider gears and most likely your rear axles won't take those 285's for long.
You might want to consider the weak points in your truck and what happens when they fail, you can't put lockers in to strengthen up the diffs.
Old 06-16-2008, 04:09 PM   #5 (permalink)
got mud?
I won't be doing lockers and HD axles, shafts, ect. for a while. I'm thinking of just doing the 235's.
DII
-- Pete
Old 06-16-2008, 04:32 PM   #6 (permalink)
Thor's Avatar
good choice, my first set of GY MT/R was 235/85. About the same size as the Camel Trophy rigs.
Todd
Old 06-16-2008, 05:09 PM   #7 (permalink)
got mud?
What are you running now thor?
DII
-- Pete
Old 06-16-2008, 06:57 PM   #8 (permalink)
Rebuilding Rover
ArmyRover's Avatar
If memory serves Thor is running 35's and has one bad ass RRC...
I would go with the 235/85 or split the difference and go for the 265/75 both 32ish tires and will be more than sufficent for your needs.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Skinny or Wide ? SCSL Wheels and Tires 39 12-07-2006 09:58 AM
