Estbnqr
I need to know wich one of the tires are going to work better with my Discovery 03 I'm really confuse with the selection of this two tires because some stores tell me the KM's are going make noise like a tank .Can any one help with their input on this tires.
#2 (permalink) | |
Rover junkie
The km's are the mud terrains, where as the ko's are the all terrains. The km's have an aggressive mud tread that aren't so noisy when new but do get louder as they wear. The ko's are relatively quiet and are a good all terrain tire. If you drive a lot on the street, go with the ko's. If you do a lot of muddy trail driving, get the km's.
I have the same size ko's that your looking into. Only thing I don't like about them is they are load rated E, or so, making the sidewalls stiff. Probably good for towing but I don't tow so its not necessary for me. that is all.
Mike '98 disco with rte and 33's '07 jk rubicon.......pretty much stock Remembering A.Stevens #13739 Quote:
On a 03 you can only run 245's unless you want to do a little trimming. 265's work really well on DII's but you should have a lift and or some trim work done to prevent sidewall cuts.
I run 265 Mt's and am on the second set, I wouldn't have anything else, even if I was doing all street driving. Yes they are slightly noiser but not enough to work about. By the way, 265's will cut into your gas mileage by as much a 2 MPG, just a thought. Mike J. |
#4 (permalink) | |
nice member
MIKE , can i run 265's mt on DII 01' se bone stock. once i get 16" wheels or do i need mods like above. thanks john ![]() |
For the most part all the 02's are the same. It varys on how much you must trim based on the type of off road wheeling you are going to be doing.
Do you need that big of a tire? Gas mikeage will hit you about 2 MPG give or take a little. It would ne cheaper to go to 245's, they cost less and no trimming. Mike J. |
Elephantitis penisitis
Hey ReferJohn - where in NorCal are you? I'm in Motown. Respond here or PM me.
#8 (permalink) | |
#9 (permalink) |
Magicly Delicious
i amlost wish i still lived in Vacaville... almost.
Kevin Owning a Land Rover is like dating a super model. Sure she has expenive tastes, complains a lot, and requires constant attention... but damn... 1994 Discovery |
#10 (permalink) |
The manual for my DII '01 says 255/65 R16 109H size. I've currently got Bridgestone Dueller H/T P255/65 R16 106S on my stock Disco.
Can anybody tell me what the last number actually means, i.e. "109H" or "106S" ? Are the KM or KO listed by estbnqr unique to a manufacturer ?
2001 Discovery SE7 |
#11 (permalink) | |
Mike J. |
