I have a 1995 RRC and will be getting a 2 inch full flex lift w/ ranchos from Rovertym. I'm decieding between the 245's -better power, mileage, no rubbing and the 265's taller and wider, slower, might rub? I don't plan on getting gears anytime soon,and I want this setup to last me for a couple of years as this will be my daily driver. let me know what you guys think.
A 265 will be fine with the 2" full flex. If you went up to 285 (33"), you would have a mild bit of trimming, but the 32's are fine.
"In certain places, at certain hours, gazing at the sea is dangerous. It is what looking at a woman sometimes is." - Victor Hugo Originally Posted by Elemental Some guys play hard to get, I play hard to want. |
265's and some help for your axles and diffs. If you are full stock, you will need to look at H.D. axles and remember those Rover diffs have a real weak point and will be effected by more rubber.
Mike |
Rebuilding Rover
if the 95 RRC is the same as the 91 on trailing arms looking into upgrading those while your doing the suspension install wouldn't be a bad idea.
"If you can't stand behind our soliders, then by all means stand in front of them." unknown quote. "Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." (offending Austrailians since 2008) http://www.wheelinrovers.com/ 91 Range Rover Classic 90 RRC Parts truck 89 Jaguar XJ6
Spoken from the guy who learned just a little too late... lol!
Mike; Doesn't the 95' RRC have the 24 splines? If so, he should be fine with the 32's. 33 seems to be the magic number for breaking stuff.
Rebuilding Rover
you are correct he should have 24 splines
I am getting the upgraded trailing arms from Rovertym with my lift. Thanks for your guy's help. I think I'm gonna go with the 265's, I just didn't want to have to upgrade axles and gearing because of it.
#9 (permalink) |
You should be okay if you wheel easy. To a certain extent tires dont really break axles, but lockers, do for sure! If you ask me the weak point is the center pin on the stock diff so even if you put HD axles in the diff would still grenade. I'd save my coin and do the diffs and the axles when time permits. The axles and stock diffs are pretty cheap. Gordo
Gordo www.floridalandroverclub.com 00 P38 4.6 blinging 92 stocker RRC 73 hybrid wheeler |
| Thread Tools | |
| Display Modes | |
| 245/75 or 265/75 | ebrover | Discovery Series I | 4 | 04-03-2008 03:44 PM |
| to trade: 255/70 MTs for 235/85 or 265/75 | DaveC | Land Rover Parts and Accessories | 8 | 09-11-2007 05:55 PM |
| 4 Toyo Open Country A/T tires (265/75) | cellulararrest | Land Rover Parts and Accessories | 0 | 05-18-2007 12:08 PM |
| Bfg 265/75 $ Sale! New! | RoverChic | Land Rover Parts and Accessories | 15 | 03-02-2007 08:09 PM |
| 265/75 BFG's | drum655 | Wheels and Tires | 8 | 02-13-2006 09:53 AM |
