Old 02-09-2006, 08:01 PM   #1 (permalink)
drum655's Avatar
Default 265/75 BFG's
I want 265/75 R 16 BFG AT's for my D2. exactly which one do i need. there are a few different 265/75 available...i guess speed rating and weight and all that stuff differs. What exact tire do i need?
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 02-09-2006, 08:04 PM   #2 (permalink)
Roads?...Where we're going, we don't need roads...
keptin's Avatar
I dont believe you can choose different ratings from that tire.....its the tire that is given the ratings.....rating per size per tire.
There is only one type of BFG A/T 265/75-16......go for it....its the best A/T money can buy.
Josh Shapiro
DII
Photos at www.kep1.com
Old 02-09-2006, 08:12 PM   #3 (permalink)
drum655's Avatar
go to discounttire.com and put in 265/75 r16...there is more than one choice....who knows?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 02-09-2006, 08:18 PM   #4 (permalink)
keptin's Avatar
Hmm.....not sure...your right though.....havent seen this before.
Anyone?
LT265/75R-16/D1 BAZ
LT265/75R-16/E1 123Q
Josh Shapiro
DII
Old 02-10-2006, 03:31 AM   #5 (permalink)
Roverhound's Avatar
Get the highest load rating you can. The higher the rating, the sturdier the sidewall.
It just doesn't matter.
Old 02-10-2006, 09:23 AM   #6 (permalink)
I don't believe they make a selection of speed rating on their tires.
BFG's come out with a 3 ply side wall which is great. I would suggest the MT's over the AT's, but that will be something you will need to consider based on the amount and type of 4wheeling you want to do.
I prefer the MT's because they are not really that much noiser then the AT's their traction is awsume, and you will get about the same mileage out of them as the AT's. I have run 2 sets so far and got nearly 50K out of the first set before I replaced them, and it wasn't that they were warn out, they just looked like hell and were starting to get noisey from the irregular wear pattern they had developed after having the S--t beat out of them.
Good luck,
Mike J.
Old 02-11-2006, 08:34 AM   #7 (permalink)
01001010's Avatar
Gallery: 15
i agree with mike..I thought the MTs would be noisier but I can hear the air rushing through my snorkel OVER the tires. They ride REAL smooth at cruising speeds. go for the MTs
JC...
01001010 is online now   Reply With Quote
Old 02-11-2006, 11:50 AM   #8 (permalink)
keptin's Avatar
x2 on that....if its a matter of noise or comfort then just go MTs....you wont feel too much of a difference, I couldnt tell they were on as far as the ride was concerned, and I could never hear them over my aftermarket exhaust.
Josh Shapiro
DII
Old 02-13-2006, 08:53 AM   #9 (permalink)
True and False.
The higher the load rating, the hotter a tire runs, the faster the tread will wear.
In the case of the BFG's, their big plus is they have a full 3 ply rating on their side walls, so when crawling @18#'s the sidewalls will take more abuse from rocks.
Mike J.
