Old 05-14-2007, 10:49 PM   #1 (permalink)
H-vegasdisco's Avatar
Default 33s on a 2 in lift
Ok I am really craving 33s on my disco right now. I have a 2in OME lift and am not afraid to cut to fit them as it is not my daily driver. The question I have has anybody run a 255/85 tire on a 2in lift? I have been told they will clear but I was hoping someone would know from experience? Oh and this will be my offroad set of tires on stock alloy wheels but I want radials and not bias ply because something that can be driven on the highway would be nice.
H-vegasdisco is offline   Reply With Quote
Old 05-14-2007, 11:10 PM   #2 (permalink)
Majesticdisco1
disco12's Avatar
I dont run them I have 32"s but I know a few who do. From what I've seen they will clear just fine however you will really have to trim the panels. Also keep in mind that some companies tires will say 33 but be a little larger or smaller. Plus 33's will cause bad fuel economy and more wear on the axles and diffs. However with 255/85/16's the risk may be a little lower because it is a narrow tire. The tires I would recommed is the BFG mud terrain or The Super swamper truxs the swampers will be less expensive and both are radials.
1996 D1
J "Crawler"
RTE 3"
BFG 33x10.50s
Old 05-15-2007, 02:13 AM   #3 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
I run Simex Jungle Trekker 33.11.50's on stock ride height. I've trimmed the arches and fit flares and have no problem even under full articulation. In places I cut about 6" of outer wheel arch away though.
It's also a 3 door, which might have been better for clearance on the rear of the rear arch.
I know someone with a 2" OME lift on a D1 and runs 235/85 Coopers. It's ok on the road and minor off road but get the rear flexing and it was bashing the out arch BIG time, it needed trimming and/or flares adding.
As for tyres, well it will depend on what terrain you dirve on. BFG Mud Terrains are popular in the US and to be honest a fairly decent Mud Terrain but there are better tyres for less money. If you are on the rocks then I hear good things about Goodyear MTR's although they really suck in the mud. But again there are cheaper alternatives.
The Best 4X4XFar
Old 05-15-2007, 08:56 AM   #4 (permalink)
gordo's Avatar
I ran 255/85 BFG MTs on my classic with a 2.5 inch lift and had to cut the body somewhat, around the rear door and front fender. Longer trailing/radius arms might fix this, but I would ask over at Dweb or search Dweb for info. Just did a 255/85 Disco search and pulled up some stuff. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
Old 05-15-2007, 09:23 AM   #5 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
Remember a lift and cranked trailing arms are all good as long as you are not flexing. A lift won't (or at least shouldn't if its a good lift) prevent the wheel stuffing itselfs as far in the wheel arch under articulation. So to aviod issues off road you need to check the clearance with each wheel fully articulated.
The Best 4X4XFar
Old 05-15-2007, 09:25 AM   #6 (permalink)
KevinNY's Avatar
D1 or D2? Makes a lot of difference.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is offline   Reply With Quote
Old 05-15-2007, 10:38 AM   #7 (permalink)
Steven Ratajczyk
stevenr's Avatar
KevinNY, He's got a D1
Timmy, If you don't mind cutting, you should be ok. Your stock driveline will suffer as a result of the tire size though. I also (personal opinion) think the tire will look too big with a 2 inch lift. I have 3 inch RTE's and 1 inch spacers and it looks about balanced with my 255/85/16's. But it's your truck and you are the only one that has to like it. Who cares what anyone else thinks. Look at me, I've got friggin white stripes all over my truck.
Good luck!
Steven Ratajczyk
'99 Disco 1 with stripes
stevenr is offline   Reply With Quote
Old 05-15-2007, 11:48 AM   #8 (permalink)
Thor's Avatar
Caution... if you trim too much the 255/85 will look small!
Todd
Carpe Rangius Roverum
Thor is online now   Reply With Quote
Old 05-15-2007, 03:36 PM   #9 (permalink)
It is for a D1. I plan on throwing on a 3in. lift eventually but since I am needing to get some new mud tires so I am hoping to go ahead and get larger.
1997 Discovery 5spd LSE
1997 Volvo 850
Old 05-15-2007, 06:47 PM   #10 (permalink)
fivespddisco's Avatar
Gallery: 10
Y not put a body lift in? get an inch more and keep you COG down? I have them in stock for a $100
Check out WWW.Lucky8LLc.com 716-898-8153 Justin
fivespddisco is offline   Reply With Quote
Old 05-15-2007, 06:49 PM   #11 (permalink)
Gallery: 10
just curious how tall are they on the truck? my 37s are only 35s on the truck
Old 05-15-2007, 09:00 PM   #12 (permalink)
I am not to much of a fan of a body lift but will consider it seriously since it is only an inch. I thought the only options were 2in. from rovertym and 2.5 from dap. I am also thinking of adding a 1in. spacer on the springs because My OME springs are probably closer to 1.5 inches of lift.
Probably will get 255/85 maxxis bighorn mudders or 255/85 trxus mts but for the right price bfg mts which may very well happen since the mud terrain is being replaced this year.
1997 Volvo 850
Old 05-16-2007, 04:23 AM   #13 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
One source I've found on the net rates the 33.11.50R15 Simex Jungle Trekker 2's at an infalted diamter of 34.00"
I can confirm that they are at least a tad taller than 33" but I've not measured them accurately. Temporarily I've got a set of 235/85R16 Bronco 4x4 Dirt Devil remoulds (look a bit like a Interco TSL) on the Discovery, I measured these and they are bang on 32" in diameter but are dwarfed by the Simex's.
The Best 4X4XFar
Old 05-16-2007, 01:43 PM   #14 (permalink)
Gallery: 10
thanks.
Old 05-16-2007, 02:43 PM   #15 (permalink)
Majesticdisco1
disco12's Avatar
Damn that is a kickass lift.
1996 D1
J "Crawler"
RTE 3"
BFG 33x10.50s
